Go Back   K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum > K-Series Technical Forum > 1992+ Civic EG / DC2 / EK K-Series Swap
Reply
Thread Tools
Old 12-02-2009, 08:59 PM   #1
AT_RSX_06
New Member
AT_RSX_06's Avatar
Default Tucking Fuel Pressure Regulator and Return Line
I know most people who want a returnless fuel rail or "tucked" fuel system have a line going from the pump to the FPR, and the from there a line going to the fuel rail that dead-ends, and a line that returns to the tank.
Rather than having both lines and FPR in the engine bay, could i tuck the FPR (and return line) somewhere in the cabin/wheel well/etc and only have the line that flows from the FPR to the rail in the engine bay?
**i know the wheel well might not be the best place, just using it as an example...**
__________________
93 EG CX- work in progress...
AT_RSX_06 is offline   Reply With Quote
Sponsored Links
Old 12-02-2009, 09:04 PM   #2
K20egcw
K20a.org Master User
K20egcw's Avatar
Default Re: Tucking Fuel Pressure Regulator and Return Line
I dont see why you cant. I wouldnt run it inside the cabin of your car tho cause I dont think thats legal if you were to take it to a track. I've heard its better to have it as close as you can to the rail cause the closer it is the more accurate it is. Keep us posted with pics when you do decide to tuck it, its always cool to see what people come up with
__________________
93' bottle fed K20A hatch
My Hatch
K20egcw is online now   Reply With Quote
Old 12-02-2009, 09:22 PM   #3
AT_RSX_06
New Member
AT_RSX_06's Avatar
Quote:
Il have to find out for sure the track legality of running fuel in the cabin.
But besides that, can anyone offer a little more information about weither or not its good or bad to have the FPR a little further away from the rail?? My K20Z1 will also be supercharged, might i have any more fuel problems than i would have with the "usual" in-bay FPR set-up? Or does pressure stay up over about an extra 2 feet of fuel line?
__________________
Old 12-02-2009, 10:38 PM   #4
K20egcw
K20egcw's Avatar
If you run a fuel pressure gauge on the rail and make sure its the right pressure you'll be fine
__________________
My Hatch
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
