spark plug threaded sleeve broke off in head ...removal process? - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 11-27-2009, 02:18 AM   #1
katman
Lifetime Member
katman's Avatar
Default spark plug threaded sleeve broke off in head ...removal process?
So, I'm helping a close friend perform a K swap into an EG. We're just about done with the swap, just figuring out why it won't start. I remove all spark plugs to inspect them and upon re installation, spark plug at cyl #4 decides to strip right as I'm torquing it snug; it suddenly just gives out and it feels like hte spark plug broke off in the head. I pull out the spark plug via. magnet and notice the whole piece of threaded area is completely missing then it sets in and I see what happened...
the whole coller portion of the sparkplug is totally missing and stuck in the head.
My question - can i remove the stuck threaded piece from the head without pulling the head off? maybe get a long ass tap n die tool??
__________________
1 3 5
2 4 6 Zigen
RIP ADAM WEST
FF SQUAD | FFS TechNet | FFS Videos
katman is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-27-2009, 02:27 AM   #2
dcloo
K20a.org Basic User
Default Re: spark plug threaded sleeve broke off in head ...removal process?
you better pull out the complete head it could be something might drop inside the piston and you just gamble with the piston
dcloo is offline   Reply With Quote Quick reply to this message
Old 11-27-2009, 04:02 AM   #3
talonxracer
K20a.org Master User
talonxracer's Avatar
A large dia easy out should get the rest of the sparkplug out.
As far as any possible debris entering the combustion chamber it would almost be cheaper to purchase a video camera with flexible neck, basically a bore scope, at Home Depot from Milwaukee tools. http://www.homedepot.com/webapp/wcs/...0&ddkey=Search to look for any debris rather than pulling the head....
__________________
Now playing with Zuki trucks!!!
PAIN is fear leaving the body....
"Sometimes it is entirely appropriate to kill a fly with a sledge hammer."
- Major I. L. Holdridge, USMC
The only good Commie, is a dead Commie ! ! !
talonxracer is offline   Reply With Quote Quick reply to this message
Old 11-27-2009, 05:44 AM   #4
chunky`
Lifetime Member
chunky`'s Avatar
when something like that happens, it's best to pull the head. Metal shavings, esp aluminum, inside a CC can be a bad bad thing.
__________________
Twisted Loop Racing
Always Outnumbered Never Outgunned
chunky` is offline   Reply With Quote Quick reply to this message
Old 11-27-2009, 08:33 AM   #5
allmotorcoupe
allmotorcoupe's Avatar
Quote:
x2
Head gasket is like $100 . . . Wouldnt that be cheaper then buying a $250 camera?
Not saying a borescope isnt useful, but for someone who will probably never use it again, a $250 tool is a little out there.
__________________
AllenBuilt/RsTech Tuned All Motor F2K Coupe - Finally went 9s.. . . Fake it, til ya make it !
allmotorcoupe is offline   Reply With Quote Quick reply to this message
Old 11-27-2009, 09:44 AM   #6
Mr_Plenty
Mr_Plenty's Avatar
Imo...remove the head.
__________________
VOUCHES: HNAperformance, civic5133, onefstek, civicmotorhead-1320WhtRex-#2, allmotora2, pb16b, tuner04civic, Stockcrx, BuiltRsx, 3k1n,*HAZARD*club
Mr_Plenty is offline   Reply With Quote Quick reply to this message
Old 11-27-2009, 01:16 PM   #7
Slociviccoupe
be carefull with an easy out. because when it tries to grip it may swell the threads on the plug out into the threads in the head. this happens to us all the time on yamaha jet ski's. we pull the head and use an allen wrench with a dome cut into it in the center. this makes a cutting surface. pound the allen into the plug from the backside till it is through the plug. then put a socket on it and hit it with the impact. should remove the plug.
best of luck. id stay away from an easy out.
Slociviccoupe is offline   Reply With Quote Quick reply to this message
Old 11-27-2009, 01:38 PM   #8
jerry4life
Lifetime Member
jerry4life's Avatar
had a couple problems like this. i just used a easy out. majority of the time that it happened on the cars i worked on, the porcelain portion of the spark plug just came out. hopefully u come out lucky.
jerry4life is offline   Reply With Quote Quick reply to this message
Old 11-27-2009, 01:50 PM   #9
91whitecivic
K20a.org Advanced User
this happened to me on my B series car....I welded a extention to a big easy out and did it like that. i was lucky the white part of the plug came out perfect and just left the threads.
Good luck
__________________
MattBUILT-I TUNE KPRO AND s300 I repair all transmissions
STRICKLY MT
K24 on the road burnin it up! Vouches-ReFleX2o3,11secSOHC,DWNVTEC
91whitecivic is offline   Reply With Quote Quick reply to this message
Old 11-27-2009, 05:13 PM   #10
chunky`
Lifetime Member
chunky`'s Avatar
BTW, this is why I ALWAYS use anti-sieze on my spark plug threads. Never had a problem with spark plugs getting stuck yet.
__________________
Twisted Loop Racing
Old 11-27-2009, 06:12 PM   #11
talonxracer
Quote:
Originally Posted by allmotorcoupe View Post
x2
Hey, any excuse to buy a new tool, that is my motto....LOL
And like Raz said, anti-sieze the new plugs. I like the permatex ultra copper anti-sieze.
__________________
Old 11-27-2009, 07:24 PM   #12
katman
Lifetime Member
katman's Avatar
thanks for the suggestions fellas
I just realized i left out some detailed info as i made my first post half asleep this morning at 3am..lol
I wish I had the plug with me to show a picture of it, but luckily the white porcelain tip is completely intact. Just the threading section of the spark plug body is the part that broke off and is stuck within threading of the spark plug hole. No small pieces broke off either.
The previous owner of this motor tightened the phuc out of all the spark plugs too! I had to use 'tard stenf + leverage to remove them plugs from the head. When I reinstalled #4 cylinder snug into the head, it suddenly became real loose, as if i stripped the head.....my jaw dropped to the floor in terror....pulled out the plug and thats when i saw the missing threaded section
I'm going to pick up an extractor and start with that first and see how that goes..I really don't want to pull the head, but if it comes to it, we will..also some anti-seize ftw
__________________
1 3 5
2 4 6 Zigen
RIP ADAM WEST
Old 11-27-2009, 08:09 PM   #13
k20z3si4dr
K20a.org Basic User
k20z3si4dr's Avatar
use anti seize. thats why its made. then you wont have to do this again after you pull the head for not using it the first time.
k20z3si4dr is offline   Reply With Quote Quick reply to this message
Old 11-27-2009, 09:16 PM   #14
katman
Lifetime Member
katman's Avatar
Quote:
thanks..
but this IS the first time the plugs have been removed by me/us for this particular K20A2. My friend just bought this swap about 2 weeks ago. It's lookin like the previous owner of this A2 was in fact a caveman.
I'm actually glad this happened now and not later
__________________
1 3 5
2 4 6 Zigen
RIP ADAM WEST
Old 11-28-2009, 05:27 AM   #15
91whitecivic
Thats exactly what happened to me,this is what i made. Please dont mind the shitty looking welds,i didnt have gas.
__________________
STRICKLY MT
Old 11-30-2009, 11:06 PM   #16
portflow
New Member
portflow's Avatar
hey katman
i have an ez-out you can borrow if you need one
this is best stuff for your spark plugs
COPASLIP
__________________
Port Flow Design
1583 w 259th Street
Harbor City, Ca. 90710
310-257-0351
http://portflow.com
[SIGPIC][/SIGPIC]
portflow is offline   Reply With Quote Quick reply to this message
Old 12-01-2009, 08:44 PM   #17
katman
Lifetime Member
katman's Avatar
bah sorry for the late reply!
Well I fixed the problem the following day thanks to the 5-piece extractor kit I picked up at Sears. I'm suuuuuuuper relieved there were no small pieces that broke off into the cylinder hole!
See attached photos.
91whitecivic, I did a similar setup to yours but sans the welding, thanks for the info tho!
Portflow/Tom? thanks for offering your EZ-out! I'll mention the Copaslip to my friend for his new spark plugs.
How are ya??
__________________
1 3 5
2 4 6 Zigen
RIP ADAM WEST
Old 12-02-2009, 04:56 AM   #18
91whitecivic
awesome! Glad you got it out in one peice.
__________________
STRICKLY MT
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
