K20a vs k20a2 vs k20z heads - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 10-22-2009, 04:10 AM   #1
jugbugz
New Member
jugbugz's Avatar
Smile K20a vs k20a2 vs k20z heads
Hi guys,
Ive been searching on the web for a while and cannot seem to find any information on the differences between the heads on these engines.
All I can find are compression ratios, bore, etc etc but nothing on head comparison.
Beside the differences on the valve train, cams etc. I want to know if the heads are the same or is the type R jdm K20a more superior? If so, then Valves should be different as well?
Thanks for you help guys.
jugbugz is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-22-2009, 04:30 AM   #2
McCoy
trial user
McCoy's Avatar
Default Re: K20a vs k20a2 vs k20z heads
All the same casting. Different valve train on the K20a and a2/z.
__________________
K-SQUAD
McCoy is offline   Reply With Quote Quick reply to this message
Old 10-22-2009, 04:41 AM   #3
jugbugz
New Member
jugbugz's Avatar
So we can say that the heads have the same part number?
Old 10-22-2009, 05:29 AM   #4
talonxracer
K20a.org Master User
talonxracer's Avatar
Yes the K20A, A2, Z1 all use the same exact head casting, there is absolutely no differences at all. The bare head's have the same part#.
__________________
Now playing with Zuki trucks!!!
PAIN is fear leaving the body....
"Sometimes it is entirely appropriate to kill a fly with a sledge hammer."
- Major I. L. Holdridge, USMC
The only good Commie, is a dead Commie ! ! !
talonxracer is offline   Reply With Quote Quick reply to this message
Old 11-27-2009, 04:31 PM   #5
k24ek
New Member
k24ek's Avatar
k24ek is offline   Reply With Quote Quick reply to this message
Old 11-29-2009, 04:46 PM   #6
Capone24
New Member
i always thought the z1 head flows better then the a2??
Capone24 is offline   Reply With Quote Quick reply to this message
Old 11-29-2009, 04:53 PM   #7
K24eg22
K20a.org Advanced User
K24eg22's Avatar
Quote:
Same head just the z1 has better cams then the a2..
__________________
JDL RACING
10.85@127 All motor EG hatch
K24eg22 is offline   Reply With Quote Quick reply to this message
Old 11-29-2009, 07:06 PM   #8
mike323
K20a.org Basic User
The JDM 07+ type R heads flows more over the rest K20 or K24 heads.
__________________
K24A2 EK Beast.
246whp & 180lbs-ft on a mustang dyno with 91octane
With power steering setup, belt driven
mike323 is offline   Reply With Quote Quick reply to this message
Old 11-29-2009, 07:11 PM   #9
nikos
nikos's Avatar
It really depends what year you are talking about... generally before 2006 and includind the american Civic Si 2006+ heads they flow the same. The 2006+ TSX flows better. The japanese type r heads from the latest years flow better but still conservative for full blown applications
nikos is offline   Reply With Quote Quick reply to this message
Old 12-02-2009, 08:57 AM   #10
JDMxDB8
New Member
JDMxDB8's Avatar
Quote:
Correct. The Z1 has JDM ITR cams.
__________________
Honda Racing Line | Mishimoto | Opak Racing | RACELINE | Spoon Sports | TunerSports
JDMxDB8 is offline   Reply With Quote Quick reply to this message
Old 12-02-2009, 11:17 PM   #11
btf
K20a.org Basic User
anyone know how i can find a side by side comparison to k20a2 and jdm k20a cams? i've seen it somewhere but haven't been able to find it yet. what's the part number of jdm cams?
btf is offline   Reply With Quote Quick reply to this message
Old 12-06-2009, 10:52 AM   #12
Teegs
K20a.org Basic User
Teegs's Avatar
What about the z3 motor?
Teegs is offline   Reply With Quote Quick reply to this message
Old 12-06-2009, 03:37 PM   #13
MrSlappy
New Member
most of the JDM Type R heads are die cast, not sand cast. they have better consistency and finish as well as less core shift.
MrSlappy is offline   Reply With Quote Quick reply to this message
Old 12-06-2009, 06:18 PM   #14
boosted98acura
boosted98acura's Avatar
So what do the K20 heads flow? I mean how many CFM's
__________________
Surje.Motorsports
boosted98acura is offline   Reply With Quote Quick reply to this message
Old 12-06-2009, 06:27 PM   #15
Cidone
Cidone's Avatar
Quote:
Okay so the 06+ tsx head flow better then type s heads? or 04-05 tsx heads?
__________________
Vouches: Saxon, CJM, K20ahondas, NecroFIesh, RagingRhino
Cidone is offline   Reply With Quote Quick reply to this message
Old 12-08-2009, 06:42 AM   #16
Cidone
Cidone's Avatar
^ Nikos im confused?
__________________
Old 12-08-2009, 07:35 AM   #17
11sec CR-X
11sec CR-X's Avatar
Quote:
Flow benches vary but most show type S heads flowing about 290 cfm!
Quote:
YES 06+ have the higher flow. I believe its the ports as well as the larger intake valves that allow it to out flow the Type S
__________________
***MANIAK-BUILT***
R.I.P. Nick Haines
***TEAM4PISTON***
11sec CR-X is offline   Reply With Quote Quick reply to this message
Old 12-08-2009, 07:41 AM   #18
mike323
K20a.org Basic User
The 06-08 TSX head flows about the same or a bit less over the K20A/K20a2/K20Z1 head. The advantage of the 06-08 TSX head is that it comes equipped with 36mm intake valve instead of 35mm, and the ports are a bit smaller, therefore more potential to improve with porting and still maintain higher velocity over the K20A/A2/Z1 head.
__________________
K24A2 EK Beast.
Old 12-08-2009, 07:50 AM   #19
k24ek
New Member
k24ek's Avatar
one says flows a bit more other says a bit less
we need a head porter to chime in that has really flowed these heads to see as id like to know i have a 08 tsx head hmmm 300 cfm ????
Old 12-08-2009, 10:07 AM   #20
Cidone
Cidone's Avatar
^ yes i have a 06 Z1 head and a 06 tsx head. I want to drop one of them on my shortblock tonight or tomorrow. i dont want to port anything anytime soon thats why im looking for the best head to use stock.
__________________
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
