K20A3 with A2 internals for boost - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 06-25-2008, 06:33 PM   #1
9JDMCRX0
K20a.org Advanced User
9JDMCRX0's Avatar
Default K20A3 with A2 internals for boost
I'm new to building k-series motors and i'm trying to get input on what interchanges with what. Here is what i'm trying to do. also any help or suggestions would be greatly appreciated.
I have the K20A3 swap.
Scrapped the head! using the tranny and the bare block
I'm planning on sleeving the block(golden Eagle) and using a good set of rods and a 9:1 piston(for turbo setup).
I'm wantingto know if the A2 crank,oil pump and pan is a direct fitment to the A3 block? I'm sure people are just wondering why i didn't go the A2 route but i got a good deal on the swap so i took it. I hear that the A3 block doesn't have the oil squirters for the pistons so this shouldn't hurt since i dont really need them with a forged piston. I'm just trying to find out what will be the better route to go before i spend the cash in getting the A3 block sleeved then not being able to put it to good use.
__________________
9JDMCRX0
9JDMCRX0 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-26-2008, 12:06 PM   #2
kommon_sense
Lifetime Member
kommon_sense's Avatar
Default Re: K20A3 with A2 internals for boost
a2 and a3 blocks are identical. Only difference is the a2 has a port machined in the back to handle the factory oil cooler. So crank, rods, pistons, oil pump, etc. are all interchangeable.
kommon_sense is offline   Reply With Quote Quick reply to this message
Old 06-26-2008, 01:45 PM   #3
vtecspeed1320
Banned
vtecspeed1320's Avatar
Yes they will work. As mentioned above. I had a k20a3 block with 06 rsx-s crank, eagle k20 rods, and wiseco 9:1. Made over 500whp to the wheels.
vtecspeed1320 is offline   Reply With Quote Quick reply to this message
Old 06-26-2008, 03:20 PM   #4
9JDMCRX0
9JDMCRX0's Avatar
This is good news for the urban green crx! Does anyone know about how much i will end up spending for golden eagle to sleeve the block? i know i have to send the pistons with the bare block so that the can get everything honed to the exact. I'm just trying to figure out what justthe high boost A3 setup is going to cost
__________________
9JDMCRX0
Old 06-26-2008, 03:21 PM   #5
9JDMCRX0
9JDMCRX0's Avatar
vtecspeed did you use your A3 pump and pan or did you swap out?
__________________
9JDMCRX0
Old 06-26-2008, 06:56 PM   #6
kommon_sense
Lifetime Member
what a3 pump are you referring to? The k20a3 from the rsx uses the same pump as the k20a2. Its the k20a3 from the ep3/si that has the balance shafts.
Old 06-26-2008, 08:17 PM   #7
vtecspeed1320
Banned
Quote:
I used the k20a2 pump and I want to say ge charges 900
Old 06-27-2008, 08:04 AM   #8
9JDMCRX0
9JDMCRX0's Avatar
see i'm not sure what a3 i have because the intake manifold isn't composite so i guess it would be out of the SI?
__________________
9JDMCRX0
Old 06-27-2008, 10:59 AM   #9
kommon_sense
Lifetime Member
then yeah, sounds like you have the si/ep3 k20a3.
Old 06-27-2008, 12:22 PM   #10
jdm04
jdm04's Avatar
This is from an a2 or rsx A3
This is from an ep3 a3 or K24
jdm04 is offline   Reply With Quote Quick reply to this message
Old 06-27-2008, 05:18 PM   #11
9JDMCRX0
9JDMCRX0's Avatar
as long as i get everything from the a2 i should be able to convert it though right? i'vee just heard so much different stuff about a3 parts that i want to change everything over to A2. almost need an A2 parts block. also need the upper half too though.
__________________
9JDMCRX0
Old 07-09-2008, 06:58 PM   #12
9JDMCRX0
9JDMCRX0's Avatar
i think i'm going to go with the s2000 pump setup. how much lower will the k24 pan set than the k20?
__________________
9JDMCRX0
Old 07-10-2008, 09:03 AM   #13
kommon_sense
Lifetime Member
I was under the impression that the k24 pan was shallower than the k20 pan. If you don't plan on constantly revving above 8500, then I would advise against the s2k pump. You also run into problems with getting a baffled pan if you want to do roadcourse events.
Old 07-10-2008, 09:23 AM   #14
9JDMCRX0
9JDMCRX0's Avatar
Maybe it is shallower than the K20. Only straight line for me though. not to much on the road racing.
__________________
9JDMCRX0
Old 07-10-2008, 09:27 AM   #15
9JDMCRX0
9JDMCRX0's Avatar
With a good tune and a good rotating assembly what boost levels will it be safe to take a stock (unsleeved) block to? Just trying to figure out where i want to spend the money for now. I dont mind building a sleeved block later on down the road but the prices are so high.
__________________
9JDMCRX0
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
