Go Back   K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum > K-Series Technical Forum > K-Series Transmission
Reply
Thread Tools
Old 03-08-2008, 03:45 AM   #1
drhonda
Fear no evo
drhonda's Avatar
Default How to use an 06 Si trans with your 02-04 engine
I've seen a bunch of threads like this. So I'd like to clarify a few things to make it work with an 02-04 wiring harness.
What you need:
06+ Civic Si transmission
1 1/16" drill bit
02-04 rsx speed ring gear Part #41312-PPP-000
02-04 rsx shifter mechanism
02-04 rsx shifter cable holder
02-04 rsx VSS
First off you need to modify the bellhousing to accept the VSS. In order to do so you need to split the cases of the trans in order to drill it. You also need to install the speed ring gear while inside. (See your manual on how to do this) I didn't have time to take pics of this.
For viewing purposes you will end up with something like this:
Now you can install the speed ring gear onto the diff. Its a slight press so hammer will slide it on. It will slide over the bearing!
Now you have this:
Now the tricky part to drill out that case. The 06 si trans has a bolt where the VSS should go but its the wrong size and its thread. But that is the exact location. So you don't need any pilot holes.
For reference of bolt:
Drilling this should be almost perfect. I'd suggest using a drill press (as i did). But you need to secure the case and drill straight! This took a lot of time to set up. 2 hours to be exact. Unfortunately I don't have any pics of my setup because my camera was MIA.
Once drilled:
In the pic above you'll see a little recessed hole. This is where you need to drill and tap to hold the vss in. (i'll edit this for exact size tap)
Drill and tapped. I did grind the top of it flush so the VSS would sit flush with the case as see below:
Now clean out that case! Use break cleaner and get all the chips and aluminum crap out! This is a very important step.
Next put the cases back together as per the manual. I'm not responsible for you being an idiot if you mess this up.
Now you can install it on the car. It bolts up perfect. But i did take out the two dowel pins for ease.
You cannot use the 06 shiftermechanism with an rsx shifter box. Its very backwards and will not even shift with the car. I tried. It gets jammed.
Now install the shifter mechanism from an 02-04 rsx. It is not a perfect match. Two of the bolts will line up. A third is way off. The fourth is there but no hole. So for that 4th that is off, I drill and tapped that. Now you have three bolts that secure it. I used a good amount of honda bond to make sure it doesn't leak. That fourth hole that doesn't line up will need to be closed off or oil will come through it. A small bolt will do.
For reference. The bolt that doesn't line up is on the upper left. The bolt that needs to be drill and tapped is upper right.
Next install the rsx shifter cable holder. You'll only need to use two of the three bolts. Bolt it down. No need to drill and tap the third (this is the bolt in the middle)
All installed:
Have fun with your new LSD and awesome gear ratios!
Yes you could swap cases blah blah. That is not the point here.
__________________
DIY and FAQ READ
One stop shop:
www.karcepts.com
Honda City Motor-sports.
drhonda is offline   Reply With Quote
Sponsored Links
Old 03-08-2008, 04:13 AM   #2
impact_blu
K20a.org Advanced User
Default Re: How to use an 06 Si trans with your 02-04 engine
Awesome write up.
impact_blu is offline   Reply With Quote
Old 03-08-2008, 05:31 AM   #3
geoscranny84
K20a.org Master User
geoscranny84's Avatar
YES........... someone make this a Sticky>> asap.
great info.... i am glad someone finally posted pics etc.... thanks for doing this!!
__________________
VOUCHES..Nos51,K20rdc,Ninetails,Onericky,Cstyleaccord,D@n ny,Jdm South,Nubs,Tiger..
>> K20/24 EG STREET WHORE <<
11.72 @ 116...NOS51 TUNED( Located in Miami,FL )
geoscranny84 is offline   Reply With Quote
Old 03-09-2008, 11:51 PM   #4
schumacher916
schumacher916's Avatar
Finally!! Thanks For Sharing The Knowledge...i Have 07 Si Tranny For The Longest Time Just Sittin Waiting For This Day To Come. God Bless
schumacher916 is offline   Reply With Quote
Old 03-10-2008, 02:25 AM   #5
signalpuke
blasting heat 36000km
signalpuke's Avatar
Sweet pics man
__________________
ランダム日本語の言葉
New to the K-Series? FAQ and DIY section
-VOUCHES/FEEDBACK
Quote:
Originally Posted by rbsjnh View Post
Aaron makes me puke
signalpuke is offline   Reply With Quote
Old 03-10-2008, 05:13 AM   #6
drhonda
Fear no evo
drhonda's Avatar
Thanks guys
__________________
DIY and FAQ READ
One stop shop:
www.karcepts.com
Old 03-12-2008, 07:25 AM   #7
schumacher916
Has everything been functional and working in the correct order? Any issues at all lately? Thanks
Old 03-12-2008, 07:56 AM   #8
drhonda
Fear no evo
drhonda's Avatar
Everything on the trans has been 100%.
I'm having a clutch issue but that's something with my clutchmasters fx300 not disengaging all the way. I have to figure that out soon.
Quote:
__________________
DIY and FAQ READ
One stop shop:
www.karcepts.com
Old 03-20-2008, 08:52 PM   #9
SilverSpoon1996
K20a.org Basic User
SilverSpoon1996's Avatar
Adjust the Throw on the Clutch pedal.. I had a similar problem with my ACT.
__________________
"There is a reason it cost more... It does what they said it is supposed to do"
SilverSpoon1996 is offline   Reply With Quote
Old 03-20-2008, 09:22 PM   #10
geoscranny84
is the 06 rsx type s tranny the same >?? as in shifter parts etc...
__________________
Old 03-20-2008, 11:22 PM   #11
PapiTuyo326
PapiTuyo326's Avatar
Quote:
yes.
Nice sticky BTW. I posted up the same process a while back, but you documented it better.
__________________
I always stock K20a2, K24a2, and K24a1 Swaps at competitive prices.
Longblocks and Full Swaps available. PM for more info.
PapiTuyo326 is offline   Reply With Quote
Old 03-20-2008, 11:26 PM   #12
PapiTuyo326
BTW<
I have done the same procedure, and I also seem to have the same issue regarding my clutch disengaging randomly (mostly under decel in gear). I have a Comp Stg 4 though. I dont see how it could be related to the trans, but what are your symptoms? I have tried adjusting the pushrod to no avail.
__________________
Old 04-02-2008, 06:55 AM   #13
TMaC_83
New Member
great pics. This is very useful. I just bought a 07 si tranny and will be puttin it into my 03 rsx
TMaC_83 is offline   Reply With Quote
Old 04-05-2008, 06:01 PM   #14
schumacher916
Did both of you get your clutch issues worked out? Is it still disengagine? I wonder if that has something to do with the swapping parts? Keep us updated. Thanks
Old 04-05-2008, 06:05 PM   #15
drhonda
Fear no evo
drhonda's Avatar
I just got this resolved the other day. It was a Clutchmaster issue with the FX300. I needed to put a washer behind the pivot ball. All is well now.
I've got about 200 miles on this setup so far and no issues. This week i'lll put about 700 on it. It will be the true test before I give her hell at an auto-x this weekend.
__________________
DIY and FAQ READ
One stop shop:
www.karcepts.com
Old 04-06-2008, 07:51 PM   #16
Scourge
K20a.org Supporter
Scourge's Avatar
Great write-up here. It's good to see this detailed. I was considering this at one point but decided to try making the stock 06 Si tranny work with my setup. I like challenging myself. I'm considering using the TSX or 06 Si shifter and for the VSS issue, I'll see if my S2000 cluster can convert it since it has a VSS OUT for systems that depend on the lower frequency signal.
__________________
Vouches: Brian K - Karcepts, Dale - K20tuned, Kris (suprfast) - Performance Spec, Iggy (LithG) - Hybrid Racing, Cory - Sparkks, Rywire, 97ek20, EvoIX4me, Sleepingblacksir, AECampeau, ekcx, eK24monster
How to make your own charge harness: http://www.k20a.org/forum/showthread.php?t=37856 06+ Civic Si vs TSX shifter, cables and tranny: http://www.k20a.org/forum/showthread.php?t=38033 OEM wheel bearing dimensions: http://www.k20a.org/forum/showthread.php?t=37607
Scourge is offline   Reply With Quote
Old 04-11-2008, 10:04 AM   #17
schumacher916
drhonda-are you talking about the washer that is listed in the parts catalog number 22103-PNA-003. It is a small bushing/washer...or is it just a plain washer. Is this a stock item or an addition?
Old 04-11-2008, 03:16 PM   #18
drhonda
Fear no evo
drhonda's Avatar
No not that washer.
This is a washer i bought at home depot and put a behind the pivot ball. There is a thread about it on here somewhere. Do a search for clutch geometry on here or club rsx.
__________________
DIY and FAQ READ
One stop shop:
www.karcepts.com
Old 04-11-2008, 03:17 PM   #19
drhonda
Fear no evo
drhonda's Avatar
Also, i've put a little over a 1000 miles on it this week. Yes, i drove that much in 7 days.
Zero problems
__________________
DIY and FAQ READ
One stop shop:
www.karcepts.com
Old 04-11-2008, 03:27 PM   #20
K20Tuned LLC
K20A.org Sponsor
K20Tuned LLC's Avatar
did you remove the 06 SI magnetic VSS and plug the hole or just left that VSS in place?
__________________
Monthly Promotions: $AVE!!
Competition Clutch 10% OFF FREE SHIPPING
Hondata PRB KPRO - New Install and Shipped from Hondata $1100
PM or Email: sales@k20tuned.com
Dale Clement (954) 326-8684
K-Series Performance Parts - K20Tuned LLC
http://www.k20tuned.com
HPC - Jose Rodriguez... R.I.P
K20Tuned LLC is offline   Reply With Quote
Reply
Bookmarks
Tags
vss
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
