Go Back   K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum > K-Series Technical Forum > 1992+ Civic EG / DC2 / EK K-Series Swap
Reply
Thread Tools
Old 11-05-2007, 05:12 AM   #1
Fuster_Cluck
K20a.org Supporter
Fuster_Cluck's Avatar
Lightbulb Official oil pan ground clearance & Axle angle PICTURE Thread!
I'd like to see 4 things in this thread:
1) Oil Pan ground clearance picture(s), and which specific oil pan you are using
2) Axle angle from tranny to hub pictures
3) Picture(s) w/ decription showing drop from fender above top of tire to ground
4) Chasis, motor mounts used, and wheel size (suspension / axles optional info)
Participants
Fuster_Cluck --> Post #1
EKoutlaw --> Post #10
littlekeel --> Post #12
drhonda --> Post #13
mugen-k --> Post #20
k20eg6 --> Post #21
Car: 1995 VX
Engine: 2003 K20A2
Engine Mounts: Hasport EGK1
Oil Pan: Stock K20a2
Axles: 2003 Type S
Suspension: Ground Control coilovers (raised all the way up) / Koni Yellow shocks
Distance from top of fender to ground: 23 3/8"
Tires: Falken Azenis 205/50/15
Wheels: Konig Heliums
Passenger side axle angle:
Driver side axle angle:
Oil pan clearance to ground (3.75"):
Suspension drop pic:
Story behind this thread:
A guy at the Nopi Nationals approached me asking how my axles were surviving with such an angle from the tranny to hubs. He stated the axles were seeing a huge incline from the tranny to the hubs. Well I forgot to look at them because I was just having too much fun at the show Weeks went by and while working on the hatch I noticed my oil pan was pretty close to planet earth. So, I decided to raise the Ground Controls approximately 1" all around. This brought the car up to a 1 finger gap between the fender and top of the tire at all four corners. I'm still thinking about raising the car another 1/2", but not sure since I don't want the 4 X 4 look
So post up those pics
__________________
1,097 picture K20a2 tear down & build upMidori Green EG thread --> HERE!!
New name......same guy
Fuster_Cluck is offline   Reply With Quote
Sponsored Links
Old 11-05-2007, 05:47 AM   #2
sirtifiedacc
K20a.org Master User
Default Re: Official oil pan ground clearance & Axle angle PICTURE Thread!
Bump I like the looks of this thread.. I think you should also include the what Oil Pan your using.
sirtifiedacc is offline   Reply With Quote
Old 11-05-2007, 01:16 PM   #3
kommon_sense
kommon_sense's Avatar
Lets get some additional information. Please also measure from the ground to the top of the arch in the wheel well. This way any and everyone can determine what their ground clearance will be before the swap regardless of what drop they have.
For example, if wheel arch is at 25", and oil pan clearance is 5", then we know there is a 20" difference. That 20" difference will be the same no matter if your car is stock height or dropped 4".
kommon_sense is offline   Reply With Quote
Old 11-05-2007, 08:17 PM   #4
ELFATHER
Heart breaker.
ELFATHER's Avatar
good info like always man
__________________
MY BUILD UP THREAD---> http://www.k20a.org/forum/showthread.php?t=32840
-HECTOR
http://www.kamispeed.com
hector@kamispeed.com
http://blog.kamispeed.com/
Pm me if you need custom brake/clutch lines
ELFATHER is online now   Reply With Quote
Old 11-05-2007, 09:57 PM   #5
k20eg6
k20eg6's Avatar
sounds like a plan ill get on it i think mines gonna be pretty bad =x
__________________
AWS Garage |TEAM IKONbought from:GST2RSX-S,suprfast,k20rDC,K20Tuned LLC,corsport,jdmsouth,cstyleaccord,juan2k2001,oneo fstek,97ek20,lilmike,juben
sold to : Martgsr,tinnny,b18_crx,HickamHatch swangnbang.com myspace
k20eg6 is offline   Reply With Quote
Old 11-06-2007, 02:27 PM   #6
purple_dc2
K20a.org Basic User
purple_dc2's Avatar
Ill get on it as soon as i get axle nuts so i can put her back on the ground.
Cuz right now i have about 32 inch pan to earth clearance.
Jack stands FTMFW
purple_dc2 is offline   Reply With Quote
Old 11-07-2007, 06:23 PM   #7
Garrett46
K20a.org Basic User
Garrett46's Avatar
I will have my euro R swap soon. I will take pictures. This thing will be low having those counter balancer shafts in the oil pan.
Garrett46 is offline   Reply With Quote
Old 11-12-2007, 03:07 PM   #8
2k3
New Member
great thread, tire size is a good idea too
2k3 is offline   Reply With Quote
Old 11-13-2007, 05:27 AM   #9
sirtifiedacc
less talky more showy
Old 11-13-2007, 11:25 AM   #10
EKoutlaw
New Member
Car: 1995 CX
Engine: 2003 K20A
Engine Mounts: Hybrid Racing
Axles: Stage 2 from "The Driveshaft Shop"
Suspension: Spoon N1 Damper kit
Drop: 22 3/4" from the ground to center of fender well
Wheels: 16x7.5/35 Enkei up front/ 16x6.5/45 98 spec ITR in rear.
(35 offset was required for the Mono blocks to work.)
Tires: Khumo Ecsta 205/45/16
(Mono blocks leave me limited in the wheel/tire department!)
Ground clearance is 3" using stock oil pan.
Passenger side axle angle: "The driveshaft shop" axles
Driver side axle angle: "The driveshaft shop" axles
Ride height is at 22 3/4" using Spoon N1 dampers.
Hybrid Racing mounts:
EKoutlaw is offline   Reply With Quote
Old 11-14-2007, 09:09 AM   #11
specialblend154
K20a.org Basic User
specialblend154's Avatar
bump for more imput!
specialblend154 is offline   Reply With Quote
Old 11-14-2007, 01:41 PM   #12
littlekeel
K20a.org Supporter
littlekeel's Avatar
Car: 1993 Si
Engine: 2003 K20A
Axles: DSS 2.9's
Suspension: PIC Select coilovers
Drop: 23" from the ground to fender
Wheels: 99 15" Si wheels
Tires: BFGoodrich G-Force Sports 195-50-15
Oil pan ground clearance ~3.75"(Stock K20a oil pan):
Passenger Side Axle Angle:
Driver Side Axle Angle:
Height from ground to fender:
littlekeel is offline   Reply With Quote
Old 11-14-2007, 02:37 PM   #13
drhonda
Fear no evo
drhonda's Avatar
Car: 1997 ek coupe
Engine: 2002 K20A2
Engine Mounts: Hasport EkK1
Axles: Hasport stage 1's
Suspension: Tokico Illumina's with eibach pro kit springs
Drop: 23 1/2" from the ground to fender
Tires: Goodyear all seasons 205-50-15
Oil pan ground clearance ~4"(Stock K20a2 oil pan):
__________________
DIY and FAQ READ
One stop shop:
www.karcepts.com
Honda City Motor-sports.
drhonda is offline   Reply With Quote
Old 12-02-2007, 11:11 PM   #14
merkone
New Member
merkone's Avatar
good thread ill post pics of mine soon.
merkone is offline   Reply With Quote
Old 12-04-2007, 05:55 AM   #15
OdyOwnage
OdyOwnage's Avatar
Damn, anyone rolling stock RSX-S axles?
__________________
Toyota Supra 2JZGE-T - SOLD
Looking for a NEW KIND of quick gift for the Wifey or Fiance?
www.naturalradiance.net
OdyOwnage is offline   Reply With Quote
Old 12-04-2007, 10:00 AM   #16
bltcivic3
K20a.org Basic User
Quote:
Jonathon, who made the first post is running stock type s axles
bltcivic3 is offline   Reply With Quote
Old 12-05-2007, 04:46 PM   #17
lsxtreme
New Member
lsxtreme's Avatar
how about ride height and angles of karr rocking k24?
lsxtreme is offline   Reply With Quote
Old 12-06-2007, 09:15 PM   #18
k20eg6
k20eg6's Avatar
pics coming in the morning i got my camera back from my gf
__________________
Old 12-07-2007, 06:33 AM   #19
sirtifiedacc
where are the clearance pics of integras?
Old 12-10-2007, 07:36 PM   #20
mugen-k
K20a.org Advanced User
mugen-k's Avatar
Car: 1995 Del Sol
Engine: K24A4
Axles: Hasport Stage 1's
Suspension: Yonaka 2-Way Adjustable Coilovers and Shocks
Drop: 24" from ground to fender
Wheels: 17" X 7.5' Volk Racing GT-Ns
Tires: Toyo Proxies FZ4 205/40ZR 17 84W
Oil pan ground clearance ~5" :
Height from ground to fender ":
__________________
Project K24 Del Sol Build Thread 12.5 @ 105 in E-Town NJ[/url]
mugen-k is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
