Air bypass control thermal valve nipple snapped!
90K views 25 replies 19 participants last post by  Aerodynamic
#1 ·
hey guys, while installing my new rbc intake manifold
the black plastic nipple on the intake air bypass control thermal valve snapped off. http://www.karcepts.com/index_files/K-IM-RBCA/K-IM-RBCA%20Installation%20Instructions.pdf as shown on page 10.
but yea was jsut wondering wat this actual valve does? does it hav a sensor or sum sort inside it? is there a another way i can replace this valve? as buyin from honda is quite expensive
cheers guys :up:
#2 ·
It bleeds extra air in around each fuel injector until the engine coolant warms up. I suppose this helps to mix the air and fuel a bit better while everything is still cold.
Your car will run without it. Plug the nipple on the manifold and the nipple on the airbox/intake. Or buy a new one. There are some online Acura/Honda dealers that are a bit cheaper.
#3 ·
you can buy another one took me forever to find it cause honda does not part it out of the water assembly...
but as he said above ive read that it will still run with out it
but out of curiosity
ive seen people plugg the water outlet where the iac valve used to be with the thermo unit or the temp sender? whichever one it was how do you go about plugging that water outlet inlet or the actual nimmple on the manifold?
i see everyone just diff bolts for the hole and little plastics caps for the nipple
what is the thread size for the inlet?
#5 ·
Air Assist Valve: This valve allows for a faster warm-up in cold weather.
When the coolant temp is at 147 degrees or BELOW the valve is opened.
The air enters the AAV from the intake tract and routes the unmetered air thru a nipple on the IM, which feeds a cavity in the head behind the IM gasket, and then back thru the IMG and into ports in the fuel injector bosses in the IM. This allows for a leaner mixture, thusly a quicker warm-up.
Here is a picture of a coolant outlet assembly.
The AAV is available in two ways. You can buy the whole coolant outlet assembly for a EP3 (here...part# 9 https://www.hondapartsdeals.com/hon...p_series_transmission=5MT&hp_series_slsareacd=KA&hp_system=A&hp_component=E++15 )
or you can get just the AAV by ordering one from a 07'Si ( here...part#8 https://www.hondapartsdeals.com/hon...series_transmission=6MT&hp_series_slsareacd=KA&hp_system=A&hp_component=E++0301 )This will require you to remove the coolant outlet assembly to remove/install the AAV if the horizontal leg is not broken.
The AAV is NOT required to be functional for your engine to operate correctly. If your AAV is damaged you do NEED to remove/plug the lines that go to it from the IM and intake. Your car may take a bit longer to warm up when it is real cold but that is all.
Another option is to remove the AAV and install a electric coolant temp probe there for a aftermarket gauge.
Doug
#10 ·
what did you use to plug the nipple on the intake manifold? i see people use these plastics nipples to cover them, but dont knwo where to get them or even what size
#11 ·
Any auto parts store will have various rubber caps to plug such nipples. Buy a variety pack and have a nipple party . . . or just take the hose in with you to get the right size.
#19 ·
#20 ·
Great Help!
I ran into the same problem, damn nipple snapped right off somewhere along the way. Also not paying $66 for something I don't need. However I am interested in the coolant temp sensor idea. Do you just get an OE cts that threads right in or do you have to get one specifically for that. If so, where can I find it?
#22 ·
I broke mine installing an intake on an EP3, I used super glue to fix it and ran the vehicle trouble free for 6 months before I gave it up to take a job in Kuwait.
