K24 main studs - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 06-11-2007, 02:29 PM   #1
suprfast
K20a.org Master User
Default K24 main studs
Just an FYI for anyone that is using new main studs in the K24(not sure of the k20), my engine builder let me know today that the F20C main studs appear to be a perfect match. Pass the word, helping out where i can
kris
suprfast is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-11-2007, 08:39 PM   #2
Uneek4L
K20a.org Basic User
Default Re: K24 main studs
benefit being? j/w
Also there is an ARP mains that will work... not that I know the part no off hand... just chiming in...
__________________
Konfidential Racing
EG builtK24 A/M
Uneek4L is offline   Reply With Quote Quick reply to this message
Old 06-11-2007, 11:47 PM   #3
suprfast
Quote:
Originally Posted by Uneek4L
benefit being? j/w
I couldnt find the part number for the ARP, so as far as i knew ARP didnt offer them. Just an FYI
kris
Old 06-12-2007, 12:25 AM   #4
Flash202
K20a.org Advanced User
Flash202's Avatar
Lightbulb Re: K24 main studs
K24 ARP main studs item #:
  • ATP4.400-1LB - Studs
  • APN12-1 - Nuts
  • APW 1316N - Washers
Got mine from lightning motorsports $99 shipped good deal
Flash202 is offline   Reply With Quote Quick reply to this message
Old 06-12-2007, 10:31 AM   #5
regamaster
K20a.org Basic User
  • APN12-1 - Nuts
Correct! I have a set as well.
regamaster is offline   Reply With Quote Quick reply to this message
Old 06-13-2007, 11:01 PM   #6
qtmac_mien
K20a.org Basic User
qtmac_mien's Avatar
damn right after i finish putting mine together then this shows up
qtmac_mien is offline   Reply With Quote Quick reply to this message
Old 10-18-2007, 12:03 AM   #7
team1320_k24eg
Lifetime Member
team1320_k24eg's Avatar
good info
__________________
Team 1320 est. 1996
R.I.P Team 1320 All Motor ITB K26 EG (aka The GOLD DIGGER).. 2006 - 4/28/12
"No nuts no glory, You can't achieve your goals if you don't take that chance"
team1320_k24eg is offline   Reply With Quote Quick reply to this message
Old 01-13-2008, 10:32 AM   #8
Uneek4L
K20a.org Basic User
Quote:
Any of you have the torque spec sheet for the ARP main studs? I know the head studs are different from OEM torque specs and lightning sent the main studs loose with no torque or spec sheet.
Thanks
__________________
Konfidential Racing
EG builtK24 A/M
Old 01-13-2008, 04:36 PM   #9
jdmcoop
K20a.org Basic User
F20C studs will not work, they are the same size as a H22 head stud. But the B16 Head studs will.
jdmcoop is offline   Reply With Quote Quick reply to this message
Old 01-13-2008, 06:36 PM   #10
Uneek4L
K20a.org Basic User
Quote:
???? The correct part numbers are already listed above, we are talking about main studs not head studs. Was this response to my question? I already have the main studs I am just looking for torque value for them.
__________________
Konfidential Racing
EG builtK24 A/M
Old 03-04-2008, 12:50 PM   #11
talonxracer
talonxracer's Avatar
Quote:
Originally Posted by Uneek4L View Post
???? I already have the main studs I am just looking for torque value for them.
Bump for an answer to this please.
__________________
Now playing with Zuki trucks!!!
PAIN is fear leaving the body....
"Sometimes it is entirely appropriate to kill a fly with a sledge hammer."
- Major I. L. Holdridge, USMC
The only good Commie, is a dead Commie ! ! !
talonxracer is offline   Reply With Quote Quick reply to this message
Old 03-04-2008, 03:23 PM   #12
regamaster
K20a.org Basic User
Quote:
55ftlbs
Old 03-05-2008, 07:55 PM   #13
Uneek4L
K20a.org Basic User
55ftlbs
with arp lube or oil?
I already forgot but I called ARP up directly they would not give me an answer without the part number though. I wrote it down but forgot where. Do not remember it being 55lbs so I would call ARP up and confirm but regamaster could be right. Sorry I couldnt help anymore.
__________________
Konfidential Racing
EG builtK24 A/M
Old 03-06-2008, 12:56 PM   #14
regamaster
K20a.org Basic User
Torco Assembly Lube or ARP Lube.
We torque ours to 55fl lbs with Torco assembly lube... I believe they (ARP actually call for 40-54ft lbs.) depending on lube.
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
