#1 |
FACEBOOK/TEAMPACMAN CLUB
Here are the best Information about K motors
#1 Basic codes/Information about K motors. Thank you.. The i-VTEC system found in the Honda K20Z3.The Honda K series engine is a four-cylinder otto cycle engine. It is available in 2.0 L and 2.4 L naturally-aspirated variants, and a 2.3 L turbocharged model. ![]() The K series engines are all equipped with DOHC valvetrains with Honda's i-VTEC variable valve timing control. Honda made this engine a big improvement over its older 4-cylinder engines by including friction-reducing technologies to reduce parasitic loss. The K-series uses a DOHC valvetrain, which utilizes roller rockers to reduce friction. The VTEC system on engines like the K20A3 is only on the intake cam, and at low RPM when not engaged, allows the engine to function as a 12-valve engine, opening only one intake valve so that the air swirls for better combustion. This VTEC system was designed with fuel economy in mind. In engines like the K20A2 found in the RSX Type-S, The VTEC system always allows the motor to run as a 16 valve engine, and when VTEC engages, its on both the intake and exhaust rockers, and opens all 4 valves even more at high RPM The K-series motors all use DI, or distributorless ignition. It uses a coil on plug system, in which each spark plug has its own coil atop it. This allows the ECU to send the spark exactly when it wants it, and removes the need for spark plug wires. A wide variety of aftermarket parts are available for the K engines, and tuners are finding that 240 and more bhp are available with routine modifications. K Series K20 K20A Found in: 2001-2005 Honda Civic Type-R (EP3) Displacement: 1998 cc Compression: 11.5:1 Power: 212 hp (215 PS, 158 kW) @ 8000 rpm Torque: 149 ft·lbf (202 N·m) @ 7000 rpm Redline: 8400 rpm 2001-2006 Honda Integra Type-R (DC5) Displacement: 1998 cc Compression: 11.5:1 Power: 217 hp (220 PS, 162 kW) @ 8000 rpm Torque: 152 ft·lbf (206 N·m) @ 7000 rpm Redline: 8500 rpm 2002-2006 Honda Accord Euro-R Displacement: 1998 cc Compression: 11.5:1 Power: 217 hp (220 PS, 162 kW) @ 8000 rpm Torque: 152 ft·lbf (206 N·m) @ 7000 rpm Redline: 8500 rpm K20A2 Found in: 2002-2004 Acura RSX Type-S and 2002-2005 Honda Civic Type R (EP, European) Displacement: 1998 cc Compression: 11.0:1 Power: 200 hp (147 kW) @ 7400 rpm Torque: 142 ft·lbf (193 N·m) @ 6000 rpm Redline: 8200 rpm K20A3 Found in: 2002-2005 Honda Civic Si Displacement: 1998 cc Compression: 9.8:1 Power: 155 hp* (119 kW) @ 6500 rpm Torque: 139 2002-2006 Acura RSX Displacement: 1998 cc Compression: 9.8:1 Power: 155 hp* (119 kW) @ 6500 rpm Torque: 139 ft·lbf* (191 N·m) @ 4000 rpm Redline: 6800 rpm (* Horsepower and torque calculations reflect new SAE J1349 procedures revised August 2004) K20Z1 Found in: 2005-2006 Acura RSX-S Displacement: 1998 cc Compression: 11.0:1 Power: 201 hp (150 kW) @ 7800 rpm (sae NET Rev 8/04) Torque: 140 ft·lbf (194 N·m) @ 7000 rpm (sae NET Rev 8/04) Redline: 8200 rpm K20Z2 Found in: 2006- Acura CSX (Canada) Displacement: 1998 cc Compression: 9.6:1 Power: 155 hp (114 kW) @ 6000 rpm (sae NET Rev 8/04) Torque: 139 ft·lbf (188 N·m) @ 4500 rpm / 188 N·m @ 4200 rpm (Singapore) Redline: 6800 rpm 2006- Honda Civic (JDM) Displacement: 1998 cc Compression: 9.6:1 Power: 155 hp (114 kW) @ 6000 rpm Torque: 139 ft·lbf (188 N·m) @ 4500 rpm Redline: 6800 rpm 2006- Honda Accord Sport(Europe) Displacement: 1998 cc Compression: 9.6:1 Power: 155 hp (114 kW) @ 6000 rpm Torque: 139 ft·lbf (188 N·m) @ 4500 rpm Redline: 6800 rpm K20Z3 This inline-4 cylinder internal combustion engine is found in the redesigned Honda Civic Si. It has an aluminum block with aluminum heads, and a bore and stroke of 86 mm*86 mm, resulting in a 2.0 Liter displacement. Found in: 2006+ Honda Civic Si 2007 Acura CSX Type-S Displacement : 1998 cc Compression : 11.0:1 Power: 197 bhp (147 kW) @ 7800 rpm (sae NET Rev 8/04) Torque: 139 lb·ft (189 N·m) @ 6200 rpm (sae NET Rev 8/04) Redline: 8000 rpm K23 K23A1 Turbocharged Found in: 2007 Acura RDX Displacement: 2300 cc (acura.com) Compression: 8.8:1 (acura.com) Power: 240 hp @ 6000 rpm (SAE net) Torque: 260 ft·lbf @ 4500 rpm (SAE net) Redline: 6800 (acura.com) Bore: 86 mm Stroke: 99 mm K24 K24A1 Found in: 2002-2006 Honda CR-V Displacement: 2354 cc Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches) Compression: 9.6:1 Power: 160 hp (119 kW) @ 6000 rpm Torque: 162 ft·lbf (220 N·m) @ 3600 rpm Redline: 6500 rpm K24A2 Found in: 2004-2006 Acura TSX Displacement: 2354 cc Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches) Compression: 10.5:1 Power: 205 hp (149 kW) @ 6800 rpm Torque: 166 ft·lbf (225 N·m) @ 4500 rpm Redline: 7100 rpm K24A3 Found in: 2003-2006 Honda Accord (Europe, Japan, and Australia) Displacement: 2354 cc Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches) Compression: 10.5:1 Power: 189 hp (140 kW) @ 6800 rpm Torque: 164.5 ft·lbf (223 N·m) @ 4500 rpm Redline: 7000 rpm K24A4 Found in: 2003-2005 Honda Accord, 2003-2006 Honda Element Displacement: 2354 cc Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches) Compression: 9.7:1 Power: 160 hp (119 kW) @ 5500 rpm Torque: 161 ft·lbf (218 N·m) @ 4500 rpm Redline: 6500 rpm K24A8 Found in: 2006/2007 Honda Accord Displacement: 2354 cc Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches) Compression: 9.7:1 Power: 166 hp (124 kW) @ 6000 RPM Torque: 160 ft·lbf @ 4000 rpm Redline: 6500 rpm I'm going to update things about k motors and give you the best info that I can and also help you to get the most power out of your k motor.. Update 5/12/07 PART #2 How to break in a New engine.. One of the most asked questions is how do I break in my new motor? The short answer is that no break-in is necessary. The only thing that is necessary is to seat the rings. All clearances and fitments should be perfect after blueprinting and precision assembly. So how many miles do you have to drive it to seat the rings? The cylinders are round, the rings are round, the bore is freshly honed and therefore your engine should be ready for tuning immediately. They will continue to seat better over a short period of time but you should be ready to go tune right away. Do I need to drive it 500 miles before I tune it? Absolutely not. How about 50 miles? No. Perhaps the best thing to do is to drive it all the way to your trailer and tow it to a competent tuner. In second position on the “things NOT to do list” is trying to break in an un-tuned engine by driving it. Too lean an air/fuel will begin to heat and distort parts, too rich will wash the oil off the cylinders causing premature wear. What is in first place on the “things NOT to do list”? Boost on an un-tuned motor. Within 2 to 3 seconds the pistons and cylinders can be ruined. Well I did put in a new base map or I’m just running off the stock Honda computer. Can’t I drive it like that for a few miles? I’m not even boosting. Well what is the base map? Just someone’s idea of what numbers will start your car. Just an educated guess by someone who does not have a clue what components you are running in your set-up. It’s not intended to drive on for any extended period of time. The same with that stock Honda computer. It could be ok but it could also be dangerously wrong. So what exactly do I do at the first engine start-up? Pull the spark plugs and crank the motor with your starter for a maximum of 30 seconds or until you see the oil pressure gauge begin to register. Re-install the plugs and wires and fire up that candle. While keeping one eye on the oil pressure gauge, use your other eye to scan for fuel leaks. If there are no fuel leaks, look under the motor for any major oil or coolant leaks. If that is ok, run the engine for 5 to 10 minutes while keeping an eye on the temperature and pressure gauges. Keep the rpm’s between 1000-3000. Shut the engine down and double-check everything. You are now ready for tuning. But my engine was already tuned from my previous set-up. Well, what happened to your previous set-up? Did you melt a stock piston or crack a cylinder? No problem because now you have forged pistons and sleeves? Wrong. Although you now have stronger components that will take more abuse, you are still not right on your air fuel mixture. Get that thing tuned properly ASAP. OK, I did it my way instead of yours and now I’m burning a lot of oil. What happened? Well basically you scarred up the skirt of the piston, messed up the surface of the cylinder wall and maybe even egg shaped the cylinder. New pistons are tapered smaller on the top to larger at the bottom of the skirt. Your piston to wall clearance is measured at the bottom of the skirt. As the engine warms up to operating temperature, the upper portion of the piston begins to expand slightly. The bottom of the skirt does not expand much. When you boost in a lean condition, the upper part of the piston expands quickly. Since the ring land area is cut smaller than the tapered skirt below it, the first part of the piston that pushes into the cylinder wall is just below the oil ring. Thus you will see the worst scarring on your piston right under the ring lands where the excess heat is the highest ![]() The more heat that is generated, the harder the piston pushes into the cylinder wall. The uninformed would blame the piston damage on bad piston to wall clearance. Untrue. If that were the problem, the damage would show up at the very bottom of the skirt. What has happened is that you have expanded your piston to the point that it has just ground itself into the cylinder wall. Keep expanding the piston by super heating it and it will push your cylinder egg shaped and maybe even balloon out the cylinder slightly. At the same time this is happening, your ring lands will begin to distort to where they will never seal properly again. Sometimes after doing this, the engine will still run but it will be a smoker. This all happens in a few seconds of high boost with a lean air fuel ratio. Also it can happen from 500 freeway miles of driving where the tune up is off enough to build excess heat at a slower rate, thus doing the same damage over a longer period of time…but the end results are the same. Death to your pistons and cylinder walls. OK, I’m just going to turn the fuel pressure way up and run extra fat, that way I won’t hurt anything. If you run too rich, you will “wash out” the rings. First, excess fuel will run down the cylinders taking the lubricating oil with it. This promotes direct metal-to-metal contact between the rings and the cylinder wall. This contact does several things. The upper ring begins to wear quickly. The middle ring is actually designed as a tapered oil scraper (it is not used for compression control at all) and the taper will begin to wear down to where it becomes flat rather than angled. When that happens, it can no longer control oil away from the combustion chamber. The last thing that happens is that pretty cross hatch design begins to wear off of the cylinder wall. While most people think that the cross hatch is there to help seat the rings, it also has a secondary purpose. That is to hold microscopic amounts of oil in the grooves to help lubricate ring to cylinder walls. With the walls smooth and no oil control help from the middle ring and a tired upper ring, oil will begin to mix with fuel in the combustion chamber. When this happens, your 93 octane fuel probably hits a value of about 80. Then detonation comes into play and begins to beat holes in the pistons, among other things. So whom can I blame for this mess? The blind machinist that honed my piston to wall clearance? That poor quality Brand X piston manufacturer? The idiot pro engine builder that assembled my block? My ex-friend that helped me put this all together? Those ignorant engineers that gave me a bad base map with my engine management system? The guy on the internet message board whose buddy knows that it takes at least 1000 miles of break in before you can tune an engine properly? All of the above? Probably none of the above. Go look in a mirror and ask…who started this engine and had no idea what the air fuel ratio was? Who just wanted to jump on it one time to see if it would haul? Who didn’t know that their injectors were at 100% duty cycle at 4000 rpm but they wanted to see how it would run at 6000 rpm? Why it was you. Get that thing tuned right away. You will notice that the more you drive a tuned motor, the stronger it will feel. This is just the rings seating in their final 5-10% as they thank you for tuning first. Thank you Earl.
__________________
IN LOVING MEMORY OF MY GRANDFATHER: 7-14-2005(ROUBEN, PIRALI) Please help and donate Haiti foundation at www.redcross.org K20A.ORG Brightside Chincky hybrid-racing.com Will Briancrower.comBrian Erlperformance.comSean driveshaftshop.comFrank Full-race.comGeoff skunk2.comTony FranaVehicles.comJohn Hondata.comDoug Myspace.com/TeamPacman Facebook.com Marouj Moradian Facebook.com TEAMPACMAN Fan club...please Add Last edited by TeamPacman; 05-13-2007 at 09:47 AM.. |
| Sponsored Links |
#2 |
JDM KING/K20a Supporter
Hey thanks for the info...
__________________
87 AH5 - B16A2 - SOLD 93 DA9 K swap!? DA - SOLD96 DC4 - SOLD 91 EF3 - SOLD 98 EK3 - :sad: *"The only bad day you can have is when you don't wake up."* *"Successful people are just ordinary people with extraordinary determination."* *SPEED means: "Freedom of the soul."* *Corruption is: "Authority plus monopoly minus transparency"* For ALL your K knowledge needs "Nooob Chat" Got questions? Get in here For True JDM Parts: JDM Addicts - Ray Vouches: Captain Destructo, KOOCHYOLOGIST, franklin-hid, guitar4ya, KiP_Swap, Blazed, Trinh, Turboman02 |
#3 |
No Boost = :(
wow nice find man...this info is very useful when wanting to find a motor of mind...
__________________
for sale k20a2 crankshaft and more for cheap http://k20a.org/forum/showthread.php?t=65346 vouches???? http://www.k20a.org/forum/showthread.php?t=21680 |
#4 |
New Member
#5 |
K20a.org Basic User
I really needed that thanks
#6 |
K20a.org Supporter
good stuff, keep it coming. This kind of info will help people who are just getting started.
#7 |
K20a.org Master User
Cool What's Next?!
__________________
Toyota Supra 2JZGE-T - SOLD
Looking for a NEW KIND of quick gift for the Wifey or Fiance? www.naturalradiance.net |
#8 |
New Member
good info thanks
#9 |
K20a.org Basic User
so unlike the b-series we don't need to break in the kseries at all?
what if its a new rebuilt? still no break in?
__________________
xs power turbo kit - SOLD greddy profec b spec II boost controller - SOLD 5- 17" roja formula 5's - SOLD 2001 b18c5 block for sale 98 gsr head port/polish, 3angle valve 4sale |
#10 |
New Member
Hi Pacman, I've noticed that your information on the k24a3 differs from kevinoneill's
if yours is correct is the k24a3 a straight bolt on to the k20a? and would it fit in the engine bay of a dc2 with no clearance issues? It appears that kevin's info is based the k24a3 being an element engine and that series has bolt on problems. |
#11 | |
New Member
Quote:
#12 | |
blasting heat 36000km
Quote:
#13 |
K20a.org Basic User
Good info greg. Thats good to know cuz imma bout to get my motor in like 2 weeks. So i know not to drive it till i tuned it. Thanx
#14 |
Banned
Location: Austin, TX . . . . . . 2nd Location: Los Angeles, CA
Good stuff!
#15 | |
Quote:
__________________
#16 |
New Member
Damm thats great info. Awesome post.....
#17 |
K20a.org Basic User
good stuff. thanks for the refrence
__________________
#18 |
New Member
this info is cool and everything but who should I believe?? get a load of this guy, ( http://www.mototuneusa.com/break_in_secrets.htm ) Check it out!
. " There are a lot of myths about engines... easy break-in is one of the biggest " KNOWLEDGE = POWER !! Tecleo aquí para la versión Español !! -------------------------------------------------------------------------------- Warning: This is a very controversial topic !! I wrote "Break-In Secrets" after successfully applying this method to approximately 300 new engines, all without any problems whatsoever. Links to this article now appear on hundreds of motorsports discussion forums from all over the world. The reason is that over time, large numbers of people have done a direct comparison between my method and the owner's manual method, and the news of their success is spreading rapidly. The results are always the same... a dramatic increase in power at all RPMs. In addition, many professional mechanics have disassembled engines that have used this method, to find that the condition of the engine is much better than when the owner's manual break-in method has been used. The thing that makes this page so controversial is that there have been many other break-in articles written in the past which will contradict what has been written here. Several factors make the older information on break-in obsolete. The biggest factor is that engine manufacturers now use a much finer honing pattern in the cylinders than they once did. This in turn changes the break-in requirements, because as you're about to learn, the window of opportunity for achieving an exceptional ring seal is much smaller with newer engines than it was with the older "rough honed" engines. In addition, there is a lot less heat build up in the cylinders from ring friction due to the finer honing pattern used in modern engines. The other factors that have changed are the vastly improved metal casting and machining technologies which are now used. This means that the "wearing in" of the new parts involves significantly less friction and actual wear than it did in the distant past. With that in mind ... Welcome to one of the most controversial motorsports pages on the internet !! -------------------------------------------------------------------------------- How To Break In Your Engine For More Power & Less Wear ! One of the most critical parts of the engine building process is the break in !! No matter how well an engine is assembled, it's final power output is all up to you !! Although the examples shown here are motorcycle engines, these principles apply to all 4 stroke engines: Street or Race Motorcycles, Cars, Snowmobiles, Airplanes & yes ... even Lawn Mowers !! ( regardless of brand, cooling type, or number of cylinders. ) These same break in techniques apply to both steel cylinders and Nikasil, as well as the ceramic composite cylinders that Yamaha uses in it's motorcycles and snowmobiles. -------------------------------------------------------------------------------- What's The Best Way To Break-In A New Engine ?? The Short Answer: Run it Hard ! Why ?? Nowadays, the piston ring seal is really what the break in process is all about. Contrary to popular belief, piston rings don't seal the combustion pressure by spring tension. Ring tension is necessary only to "scrape" the oil to prevent it from entering the combustion chamber. If you think about it, the ring exerts maybe 5-10 lbs of spring tension against the cylinder wall ... How can such a small amount of spring tension seal against thousands of PSI (Pounds Per Square Inch) of combustion pressure ?? Of course it can't. How Do Rings Seal Against Tremendous Combustion Pressure ?? From the actual gas pressure itself !! It passes over the top of the ring, and gets behind it to force it outward against the cylinder wall. The problem is that new rings are far from perfect and they must be worn in quite a bit in order to completely seal all the way around the bore. If the gas pressure is strong enough during the engine's first miles of operation (open that throttle !!!), then the entire ring will wear into the cylinder surface, to seal the combustion pressure as well as possible. The Problem With "Easy Break In" ... The honed crosshatch pattern in the cylinder bore acts like a file to allow the rings to wear. The rings quickly wear down the "peaks" of this roughness, regardless of how hard the engine is run. There's a very small window of opportunity to get the rings to seal really well ... the first 20 miles !! If the rings aren't forced against the walls soon enough, they'll use up the roughness before they fully seat. Once that happens there is no solution but to re hone the cylinders, install new rings and start over again. Fortunately, most new sportbike owners can't resist the urge to "open it up" once or twice, which is why more engines don't have this problem !! An additional factor that you may not have realized, is that the person at the dealership who set up your bike probably blasted your brand new bike pretty hard on the "test run". So, without realizing it, that adrenaline crazed set - up mechanic actually did you a huge favor !! -------------------------------------------------------------------------------- Here's How To Do It: There are 3 ways you can break in an engine: 1) on a dyno 2) on the street, or off road (Motocross or Snowmobile.) 3) on the racetrack -------------------------------------------------------------------------------- On a Dyno: Warm the engine up completely !! Then, using 4th gear: Do Three 1/2 Throttle dyno runs from 40% - 60% of your engine's max rpm Let it Cool Down For About 15 Minutes Do Three 3/4 Throttle dyno runs from 40% - 80% of your engine's max rpm Let it Cool Down For About 15 Minutes Do Three Full Throttle dyno runs from 30% - 100% of your engine's max rpm Let it Cool Down For About 15 Minutes Go For It !! Frequently asked Question: What's a dyno ?? A dyno is a machine in which the bike is strapped on and power is measured. It can also be used to break in an engine. NOTE: If you use a dyno with a brake, it's critical during break - in that you allow the engine to decelerate fully on it's own. (Don't use the dyno brake.) The engine vacuum created during closed throttle deceleration sucks the excess oil and metal off the cylinder walls. The point of this is to remove the very small (micro) particles of ring and cylinder material which are part of the normal wear during this process. During deceleration, the particles suspended in the oil blow out the exhaust, rather than accumulating in the ring grooves between the piston and rings. This keeps the rings from wearing too much. You'll notice that at first the engine "smokes" on decel, this is normal, as the rings haven't sealed yet. When you're doing it right, you'll notice that the smoke goes away after about 7-8 runs. Important Note: Many readers have e-mailed to ask about the cool down, and if it means "heat cycling" the engine. No, the above "cool down" instructions only apply if you are using a dyno machine to break in your engine. The reason for cool down on a dyno has nothing to do with "Heat Cycles" !!! Cool Down on a dyno is important since the cooling fans used at most dyno facilities are too small to equal the amount of air coming into the radiator at actual riding speeds. On a dyno, the water temperature will become high enough to cause it to boil out of the radiator after about 4 dyno runs. This will happen to a brand new engine just as it will happen to a very old engine. (Always allow the engine to cool down after 3 runs whenever you use a dyno.) If you're breaking your engine in on the street or racetrack, the high speed incoming air will keep the engine temperature in the normal range. (In other words, you don't have to stop by the side of the road to let your bike cool down.) What about "heat cycling" the engine ?? There is no need to "heat cycle" a new engine. The term "heat cycle" comes from the idea that the new engine components are being "heat treated" as the engine is run. Heat treating the metal parts is a very different process, and it's already done at the factory before the engines are assembled. The temperatures required for heat treating are much higher than an engine will ever reach during operation. The idea of breaking the engine in using "heat cycles" is a myth that came from the misunderstanding of the concept of "heat treating". On the Street: Warm the engine up completely: Because of the wind resistance, you don't need to use higher gears like you would on a dyno machine. The main thing is to load the engine by opening the throttle hard in 2nd, 3rd and 4th gear. Realistically, you won't be able to do full throttle runs even in 2nd gear on most bikes without exceeding 65 mph / 104 kph. The best method is to alternate between short bursts of hard acceleration and deceleration. You don't have to go over 65 mph / 104 kph to properly load the rings. Also, make sure that you're not being followed by another bike or car when you decelerate, most drivers won't expect that you'll suddenly slow down, and we don't want anyone to get hit from behind !! The biggest problem with breaking your engine in on the street (besides police) is if you ride the bike on the freeway (too little throttle = not enough pressure on the rings) or if you get stuck in slow city traffic. For the first 200 miles or so, get out into the country where you can vary the speed more and run it through the gears ! Be Safe On The Street ! Watch your speed ! When you're not used to the handling of a new vehicle, you should accelerate only on the straightaways, then slow down extra early for the turns. Remember that both hard acceleration and hard engine braking (deceleration) are equally important during the break in process. On the Racetrack: Warm the engine up completely: Do one easy lap to warm up your tires. Pit, turn off the bike & check for leaks or any safety problems. Take a normal 15 minute practice session and check the water temperature occasionally. The racetrack is the perfect environment to break in an engine !! The combination of acceleration and deceleration is just the ticket for sealing the rings. Go For It !! -------------------------------------------------------------------------------- Yeah - But ... the owner's manual says to break it in easy ... Notice that this technique isn't "beating" on the engine, but rather taking a purposeful, methodical approach to sealing the rings. The logic to this method is sound. However, some will have a hard time with this approach, since it seems to "go against the grain". The argument for an easy break-in is usually: "that's what the manual says" .... Or more specifically: "there are tight parts in the engine and you might do damage or even seize it if you run it hard." Consider this: Due to the vastly improved metal casting and machining technologies which are now used, tight parts in new engines are not normal. A manufacturing mistake causing a tight clearance is an extremely rare occurrence these days. But, if there is something wrong with the engine clearances from the factory, no amount of gentle running will fix the problem. The real reason ??? So why do all the owner's manuals say to take it easy for the first thousand miles ??? This is a good question ... -------------------------------------------------------------------------------- Q: What is the most common cause of engine problems ??? A: Failure to: Warm the engine up completely before running it hard !!! Q: What is the second most common cause of engine problems ??? A: An easy break in !!! Because, when the rings don't seal well, the blow-by gasses contaminate the oil with acids and other harmful combustion by-products !! Ironically, an "easy break in" is not at all what it seems. By trying to "protect" the engine, the exact opposite happens, as leaky rings continue to contaminate your engine oil for the rest of the life of your engine !! -------------------------------------------------------------------------------- What about running it in the garage ??? Maybe you have a new snowmobile and it's not quite winter yet, or a new bike and it's snowing... The temptation to fire up a new vehicle in the garage just to "hear" the new engine run can be very strong. This is the worst thing for a new engine, in fact, my advice is: don't even start it up until you're ready to warm it up for the first ride. The reason is that brand-new rings don't seat all the way around the 360 degrees of their circumference. The gas pressure from hard acceleration forces the rings to contact the cylinder around their entire circumference, which is the only way the rings can properly wear into the exact shape of the cylinder to seal the combustion pressure. Now, imagine if the engine is run in the garage. There is no load on the engine, so the rings are just going up and down "along for the ride". Only a small portion of their surface is actually contacting the cylinder wall. The ring area that does contact the cylinder wears down the roughness of the honing pattern on the cylinder walls. Once the roughness of the cylinder is gone, the rings stop wearing into the cylinder. If this happens before the entire ring has worn into the cylinder and sealed, you will have a slow engine no matter how hard it gets ridden after that point. The difference between what happens in an engine running in the garage, versus one being ridden is a hard concept to put into written words, so if I may use the sounds that we all can relate to: it's the difference between "zing-zing-zing" and "bwaaaaaaaaaAAAAAA" During "zing-zing-zing" the rings don't get loaded for more than a split second, whereas during "bwaaaaaAAAAAA", the engine is in 100% ring sealing mode. -------------------------------------------------------------------------------- Recent Snowmobile Info: Yamaha's break-in recommendation for the RX1 has been to idle the engine for 15 minutes. Some owners found that the heat build up from doing this was so extreme, that their taillight had begun melting (!!!) Yamaha has since changed the recommendation to three 5 minute idle periods. Why would Yamaha recommend a break in method which will prevent the rings from sealing as well as possible ?? This is a good question ... -------------------------------------------------------------------------------- A Picture's Worth A Thousand Words: The piston on the right was broken in as per MotoMan's instructions. After a full season of hard racing: - Perfect Ring Seal ... - No Scuffing ... - Lots of Trophies !!! These Honda F3 pistons show the difference. Although these pistons came out of engines which were raced for a full season, they weren't set-up with any special clearances or other preparation. These engines were never worked on prior to being raced. They were totally stock as built by Honda. The only difference was the break in method they used... The one on the right was broken in as per MotoMan's instructions. The one on the left was broken in exactly according to the owner's manual. The resulting leaky rings have allowed pressure to "blow by" down into the crankcase on acceleration, and oil to "suck-up" into the combustion chamber on deceleration. Needless to say, this bike was slow !! It's up to you: The loss in power from an easy break-in and the resulting poor ring seal can be anywhere from 2% - 10% !! In other words: The gain in power from using this break-in method can be anywhere from 2% - 10% !! -------------------------------------------------------------------------------- Update - Some have felt that the piston which was broken in hard in the above photo is too clean to be true !! "That piston is impossible, there must be some trick going on." So, here I present: "The Impossible Piston Museum" Here are 14 pistons from 14 different bikes, with several manufacturers represented. Some are from streetbikes and some from racebikes. All of the engines had the correct jetting, the reason some have black carbon deposits is because they were run on "pump gas", which burns dark regardless of the jetting. Whereas the lighter ones were run on oxygenated race fuel, which gives a very light tan to gray color. (Many of the black-carboned pistons were from racebikes.) Disclaimer: Absolutely no photo altering or physical cleaning of the pistons is allowed in the museum !! We run a legit exhibit, and all the artifacts on display are 100% genuine. Note: The controversial piston in the above picture is the last one in the middle row, and it's indicated by the arrows. You can take a closer look by clicking on the photos to see the full sized versions: . . << It looks like there are more than 14 pistons, because the area in the 3 photos overlap. It's 3 segments of a panorama photo to give you multiple views of this extraordinarily rare collection. The pistons have been stacked for display purposes only, they aren't going back into engines. Always be super careful when handling pistons, as the aluminum is soft and very easily dented, causing combustion leakage, and friction ... neither of which is good for power. As in any museum, some of the specimens are better examples than others, but the point is that none have any leakage past the top ring, because they were all broken in by the method described here ! The only impossible thing about these pistons ... is that it's impossible to achieve this result with an easy break-in. -------------------------------------------------------------------------------- What about street bikes ??? This piston is from a 650 Honda Hawk. The brown discoloration that extends up into the piston pin bore is burnt oil from the extreme heat leaking past all 3 rings !! The uneven heat leakage was so bad, that it caused the cylinder to distort and become out of round, causing piston to cylinder scuffing in the tight part of the "oval" cylinder. When I showed the customer his pistons, he said: " I don't understand how that happened, I followed the owner's manual break-in instructions 100% !! " Why would Honda recommend a break in method which will prevent the rings from sealing as well as possible ?? This is a good question ... -------------------------------------------------------------------------------- Q: What's the third most common cause of engine problems ??? A: Not changing the oil soon enough after the engine is first run !! Change Your Oil Right Away !! The best thing you can do for your engine is to change your oil and filter after the first 20 miles. Most of the wearing in process happens immediately, creating a lot of metal in the oil. Plus, the amount of leftover machining chips and other crud left behind in the manufacturing process is simply amazing !! You want to flush that stuff out before it gets recycled and embedded in the transmission gears, and oil pump etc... Why do the manufacturers recommend waiting until 600 miles to flush out all the loose metal ??? This is a good question ... -------------------------------------------------------------------------------- 3 more words on break- in: NO SYNTHETIC OIL !! Use Valvoline, Halvoline, or similar 10 w 40 Petroleum Car Oil for at least 2 full days of hard racing or 1,500 miles of street riding / driving. After that use your favorite brand of oil. -------------------------------------------------------------------------------- Viewer Questions: Q: If break- in happens so quickly, why do you recommend using petroleum break- in oil for 1500 miles ?? A: Because while about 80% of the ring sealing takes place in the first hour of running the engine, the last 20% of the process takes a longer time. Street riding isn't a controlled environment, so most of the mileage may not be in "ring loading mode". Synthetic oil is so slippery that it actually "arrests" the break in process before the rings can seal completely. I've had a few customers who switched to synthetic oil too soon, and the rings never sealed properly no matter how hard they rode. Taking a new engine apart to re - ring it is the last thing anyone wants to do, so I recommend a lot of mileage before switching to synthetic. It's really a "better safe than sorry" situation. Q: My bike comes with synthetic oil from the factory, what should I do ?? A: I recommend changing the factory installed synthetic oil back to petroleum for the break-in period. Q: What about the main and rod bearings, don't they break - in ?? A: Actually, the operation of plain bearings doesn't involve metal to metal contact !! The shiny spots on used bearings are caused from their contact with the crankshaft journals during start up after the engine has been sitting a while, and the excess oil has drained off. This is the main reason for not revving up the engine when it's first started. The subject of plain bearings is one of the most mysterious aspects of engines, and will be covered in a future issue of Power News. In it, I'll reveal more information that fully explains the non-contact phenomenon. Q: Why change the oil at 20 miles ?? Doesn't the oil pick up screen catch the aluminum bits ??? A: It's true that the screen stops the big pieces, but many areas of the engine aren't within the oil filtration system. The oil that is splashed around will circulate metal debris to the lubricated bearing surfaces. For example, transmission gears and their ball bearings are unprotected by the filtration system, and even the cam chain makes a perfect "conveyer belt" to bring metal debris up into the cylinder head !! A close examination of a new engine will reveal lots of aluminum deposits on steel parts. This aluminum coats and tightens up the clearances of the parts, which creates a loss of power. Most of the time I spend "blueprinting" an engine is actually inspecting every part and "de-aluminizing" them !! I prefer to remove the oil pan and clean the aluminum bits out of a new engine out that way, but a $20 oil change is an easy and inexpensive way to flush the initial particles that come loose in the first miles. Q: What about motorcycle V.S. car oils ??? A: This is a topic all by itself !! It will be covered in a future issue of Power News. Q: Will this break - in method cause my engine to wear out faster ??? A: No, in fact, a poor ring seal will allow an increase in the by products of combustion to contaminate the oil. Acid contamination and oil consumption are the 2 reliability problems which are the result of an "owner's manual" or "magazine tech article" style easy break-in. By following the instructions on this page, you'll find that your oil is cleaner and the engine will rev quicker. Plus, you'll have much better torque and power across the power range from the vastly improved ring seal. Reliability and Power are 100% connected !! -------------------------------------------------------------------------------- What are some of the other common myths about engines ?? Here are some popular engine tuning concepts in which the truth is quite the opposite of what is commonly thought: - Bigger Ports - Polishing The Ports - Ignition Advancers - Flatslide Carburetors - Fuel Injection Tuning - Cam Timing - Jetting Intake Porting !! Smaller Intake Ports Gain 7 % More Power !! Never Before Seen in Magazines . Learn How to Do it Yourself !! If you've found the Break In Secrets article interesting, please sign up for Power News Magazine. Find out why the manufacturers recommend an easy break in, and the revealing evidence which provides answers to those good questions we've all wondered about. (The questions the manufacturers wish you wouldn't ask ...) Plus, find out how much more power the readers of this page have gained, as well as photos and analysis of other engine parts in long term tests of this process. Whether you're into motorcycles, cars or snowmobiles, Power News Magazine contains the most provocative engine tech articles in the world ... ... you'll never think about engines in the same way again !! Over 12,000 Subscribers !! Sign Up Now !! MotoMan's " Power News Rocks !! " Amazing New Information Never Seen in Motorcycle Magazines !! Now get instant access to the secret links to all 23 past issues of Power News !! . It's Free Just Enter Your E Mail Address Here: Then Click Here: If You Like If you feel that Power News will help you get more fun out of your vehicle ... Then, I'd like to ask you to take some time and help me out. Please tell your friends about it !! And... if you roadrace, forward this to your Mechanic !! Thanks for all your support !! - Pat McGivern aka "MotoMan" Tell 3 Friends About Click Here: Tell Your Friends About Power News !!! Hey.Superbikers: Tech Questions ? Fan Mail ? Feedback ? Click Here: MotoMan ! Click Here: Don't Let Your Bike Lose Power This Winter |
#19 |
New Member
So if I bought a used k20a engine with the majority of the parts to do a swap, would I still have to tune the engine?
Or would I not have to tune it at all? Thanks nefarious3d |
#20 |
You could run one of the basemaps in Kpro.
| Bookmarks |
| Thread Tools | |
