Go Back   K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum > Main K20a.org Forum > Engine Building
Reply
Thread Tools
Old 12-17-2006, 09:27 PM   #1
Froth
K20a.org Master User
Froth's Avatar
Default The Definitive K20/24 Sensor Comparison.
This is a comparison of every major sensor located on the Cylinder Head/Engine block of a K24/20. However, this is not just for the electrical sensors but anything that is used to actuate a particular engine function. I got the idea after listing the VTC sensor in a thread on here, All comparisons are done using the following vehicle models. RSX, RSX-S, TSX, Accord, CRV, Civic, Element. I am not including the DC5-R because they share so many commonalities with the RSX-S it would be pointless. The most common used parts will be BOLDED aswell as any of those common parts that match eachother. All emissions sensors are excluded as they are mostly particular to the specific vehicle throttle body.
Sensors/Valve Assemblys:
-Knock Sensor
Accord 04-07 Knock Sensor P/N: - 30530-PPL-A01
Civic 03-05 Knock Sensor P/N: - 30530-PPL-A01
CRV 03-07 Knock Sensor P/N: - 30530-PPL-A01
Element 03-07 Knock Sensor P/n: - 30530-PPL-A01
TSX 04-07 Knock Sensor P/N: - 30530-PPL-A01
RSX 02-06 Knock Sensor P/N: - 30530-PPL-A01
RSX-S 02-06 Knock Sensor P/N: - 30530-PRB-A01
Civic Si 06-07 Knock Sensor P/N: - 30530-PRC-003
-Crank Position Sensor
Accord 03-07 Crank Position Sensor P/N: - 37500-RAA-A01
Element 03-07 Crank Position Sensor P/N: - 37500-RAA-A01
TSX 04-07 Crank Position Sensor P/N: - 37500-RAA-A01
CRV 02-07 Crank Position Sensor P/N: - 37500-PNB-003
Civic 03-07 Crank Position Sensor P/N: - 37500-PNB-003
RSX-S 02-06 Crank Position Sensor P/N: - 37500-PNB-003
RSX 02-06 Crank Position Sensor P/N: - 37500-PNB-003
Civic Si 06-07 Crank Position Sensor P/N: - 37500-PNB-003
-Camshaft TDC sensor
Civic 02-07 Camshaft TDC Sensor P/N: - 37510-PNB-003
RSX 02-06 Camshaft TDC Sensor P/N: - 37510-PNB-003
RSX-S 02-06 Camshaft TDC Sensor P/N: - 37510-PNB-003
CRV 03-06 Camshaft TDC Sensor P/N: - 37510-PNB-003
CRV 07 ONLY Camshaft TDC Sensor P/N: - 37510-PNB-003 <-Exhaust- // 37510-RAA-A01 <-Intake-
Accord 03-07 Camshaft TDC Sensor P/N: - 37510-PNB-003 <-Exhaust- // 37510-RAA-A01 <-Intake-
Element 03-07 Camshaft TDC Sensor P/N: - 37510-PNB-003 <-Exhaust- // 37510-RAA-A01 <-Intake-
TSX 04-07 Camshaft TDC Sensor P/N: - 37510-PNB-003 <-Exhaust- // 37510-RAA-A01 <-Intake-
Civic Si 06-07 Camshaft TDC Sensor P/N: - 37510-PNB-003 <-Exhaust- // 37510-RAA-A01 <-Intake-
-MAP Sensor
Accord 03-04 MAP Sensor P/N: - 37830-PGK-A01
CRV 02-04 MAP Sensor P/N: - 37830-PGK-A01
Civic 01-05 MAP Sensor P/N: - 37830-PGK-A01
RSX 02-04 MAP Sensor P/N: - 37830-PGK-A01
RSX-S 02-04 MAP Sensor P/N: - 37830-PGK-A01
TSX 04-07 MAP Sensor P/N: - 37830-PGK-A01
Civic Si 06-07 MAP Sensor P/N: - 37830-PNC-003
-Water Temp. Sensor
Accord 03-07 Water Temp. Sensor P/N: - 37870-PNA-003
CRV 02-06 Water Temp. Sensor P/N: - 37870-PNA-003
Civic 03-07 Water Temp. Sensor P/N: - 37870-PNA-003
Element 03-07 Water Temp. Sensor P/N: - 37870-PNA-003
RSX 02-06 Water Temp. Sensor P/N: - 37870-PNA-003
RSX-S 02-06 Water Temp. Sensor P/N: - 37870-PNA-003
TSX 04-07 Water Temp. Sensor P/N: - 37870-PNA-003
Civic Si 06-07 Water Temp. Sensor P/N: - 37870-PNA-003
-VTC Spool valve assembly
Accord 03-05 VTC Spool Assembly P/N: - 15810-RAA-A01
CRV 03-05 VTC Spool Assembly P/N: - 15810-RAA-A01
Civic 03-05 VTC Spool Assembly P/N: - 15810-RAA-A01
Element 03-05 VTC Spool Assembly P/N: - 15810-RAA-A01
RSX 02-06 VTC Spool Assembly P/N: - 15810-RAA-A01
RSX-S 02-06 VTC Spool Assembly P/N: - 15810-PRB-A01
TSX 04-05 VTC Spool Assembly P/N: - 15810-PRB-A01
Civic Si 06-07 VTC Spool Assembly P/N: - 15810-PRB-A03
-VTC Oil Control Valve Assembly
Accord 03-07 VTC Oil Control Assembly P/N: - 15830-RAA-A01
Element 03-07 VTC Oil Control Assembly P/N: - 15830-RAA-A01
CRV 03-05 VTC Oil Control Assembly P/N: - 15830-PNC-003
Civic 03-05 VTC Oil Control Assembly P/N: - 15830-PNC-003
RSX-S 02-04 VTC Oil Control Assembly P/N: - 15830-PNC-003
RSX 02-04 VTC Oil Control Assembly P/N: - 15830-PNC-003
TSX 04-07 VTC Oil Control Assembly P/N: - 15830-RBB-003 (same as 05-06 RSX-S)
Civic Si 06-07 VTC Oil Control Assembly P/N: - 15830-RBB-003
-Timing Chain Tensioner
02-07 CRV - 14510-PNA-003 (K24A1 and K24Z1)
03-05 Civic Si - 14510-PNA-003 (K20A3)
03-07 Accord - 14510-PNA-003 (K24A4 and K24A8)
02-06 RSX Base - 14510-PNA-003 (K20A3)
03-07 Element - 14510-RAA-A01 (K24A4)
02-06 RSX-S - 14510-PRB-A01 (K20A2 and K20Z1)
04-07 TSX - 14510-PRB-A01 (K24A2)
06-07 Civic Si - 14510-PRB-A01 (K20Z3)
07 Acura RDX - 14510-RWC-A01 (K23A1, Turbo)
I was bored, and it helps if you're buying things that may or may not be missing one of these. Now you know what to ask for/what to look for
-Froth
Edit: Added 06-07 Civic Si thanks to civicmexicano.
Edit: Added Timing Chain Tensioners (7/02/07)
Edit: Added updated Camshaft TDC sensors thanks to BlackEgk20a & Scourge. (11/11/07)
Edit: Added 07 ONLY CRV Camshaft TDC sensor update, Discovered myself while doing the other updates. (11/11/07)
__________________
Hondas are like Legos. Cheap, Entertaining, and Easy to put together.
- 2002 New Formula Red AP1.
Read, Comprehend, Post. In that order.
Froth is online now   Reply With Quote
Sponsored Links
Old 12-17-2006, 09:56 PM   #2
tibbie_03
K20a.org Advanced User
tibbie_03's Avatar
Default Re: The Definitive K20/24 Sensor Comparison.
So what this is saying is that on the k24/k20 swap, the sensors in bold are the only sensors that will function with a K20A2 engine harness and read correctly? Or unless you have the oppostite connector from the OEM harness you are using the sensor from?
__________________
Vouches: Bocar, SpeedDreamz.com, Rafal, Froth, Big_Teggie, typeSwerx, pb16b, em2typeflex, typerman2001, N.O.B., 1320WhtRex, 2gr84u, txtypes, and jyr3x, mike323, 02ep3si, josh95, k20rDC, nahatch2000, 94ex-vtec, cstyleaccord and much more...
tibbie_03 is offline   Reply With Quote
Old 12-17-2006, 10:02 PM   #3
Froth
Froth's Avatar
Basically? Yes. The bolded sensors are what is KNOWN to work with an RSX-S harness and the unbolded things need to either be re-pinned to work or have a plug switched out from the stock harness. The VTC Spool valve and Oil Control Valve however I am unsure of, If anyone can clear it up that would be fantastic.
__________________
Old 12-18-2006, 11:33 PM   #4
Lenthrax
K20a.org Basic User
if you have more time, do a pricing too hehe
__________________
IPS Powered
Lenthrax is offline   Reply With Quote
Old 12-18-2006, 11:38 PM   #5
Froth
Froth's Avatar
All you have to do is copy the part number and go look it up :P I'm not even that lazy and the prices make it look all jumbled up.
__________________
Old 01-17-2007, 10:16 AM   #6
k20eg6
k20eg6's Avatar
great information bro thanks
__________________
AWS Garage |TEAM IKONbought from:GST2RSX-S,suprfast,k20rDC,K20Tuned LLC,corsport,jdmsouth,cstyleaccord,juan2k2001,oneo fstek,97ek20,lilmike,juben
sold to : Martgsr,tinnny,b18_crx,HickamHatch swangnbang.com myspace
k20eg6 is offline   Reply With Quote
Old 01-17-2007, 11:04 AM   #7
jon v
Moderating your shit...
jon v's Avatar
thank you sir...
__________________
Quote:
Originally Posted by Gage View Post
The Rotrex Supercharger killed Turbocharging, what, a year or two ago? It just takes a long time in this instance for all the bodies to hit the floor.
Quote:
Originally Posted by Mr.E.G.
think about what you are saying here. educated people are saying that some portions of this safety device are in direct conflict with this little thing called physics and you are willing to ignore that simply because of the cage builders reputation? that sounds like religion to me. welcome to the church of fanboyology.
jon v is offline   Reply With Quote
Old 01-17-2007, 12:14 PM   #8
seek167
K20a.org Supporter
seek167's Avatar
can we get this as a sticky
seek167 is online now   Reply With Quote
Old 02-07-2007, 04:41 PM   #9
civicmexicano
K20a.org Basic User
civicmexicano's Avatar
sticky this
civicmexicano is offline   Reply With Quote
Old 02-07-2007, 05:39 PM   #10
Buitrex
K20a.org Basic User
Buitrex's Avatar
How about TPS sensors?
Buitrex is offline   Reply With Quote
Old 02-07-2007, 07:31 PM   #11
Froth
Froth's Avatar
TPS Sensors are not sold individually by Honda/Acura. They are outsourced by Keihin and would need to bought in extreme bulk quantities(500+) to be sold individually.
__________________
Old 02-07-2007, 07:36 PM   #12
tibbie_03
tibbie_03's Avatar
But would they be interchangable? If so, which ones work on which throttle bodies and which dont?
Man...we're putting Froth to work... do work son!!
__________________
Old 02-07-2007, 09:01 PM   #13
Froth
Froth's Avatar
Accord/CRV are interchangeable to the best of my knowledge, RSX-S is alone...unsure if anything else matches up to it.
__________________
Old 02-08-2007, 02:40 AM   #14
NtegraDryvr
NtegraDryvr's Avatar
So for those of us doing either k24/k20 swaps or K24a2 tsx swaps into our dc/eg/ek/etc chassis we need the 37500-PNB-003 crank sensor out of a Type-S which is like $55 from hondapartsdeals.com?? If so, are there any alternatives to using the existing sensor already in my motor?
__________________
Humble Performance Garage Sale
PM, IM, E-Mail, or Call for parts & labor!
918-461-8951 - 8117 E. 48th St Tulsa, OK 74145
NtegraDryvr is offline   Reply With Quote
Old 02-08-2007, 12:18 PM   #15
Froth
Froth's Avatar
If you have part of the stock TSX harness you can Repin/Re-splice the TSX CPS plug onto the RSX-S harness and use it that way, then you can retain the stock TSX CPS. That seems to be the norm.
__________________
Old 02-08-2007, 01:27 PM   #16
tibbie_03
tibbie_03's Avatar
Other than the TSX CPS, can the A1/A3/A4 CPS be used the same way?
__________________
Old 02-08-2007, 01:44 PM   #17
Froth
Froth's Avatar
Yes. Minus the K24A1 CPS, as it is identical to the RSX-S CPS and requires no modifications to work with an RSX-S harness :P
__________________
Old 02-17-2007, 08:45 AM   #18
rsxmachine
rsxmachine's Avatar
Quote:
someone asked me about a VTC phase gap error using a TSX head with a 50° VTC gear. I noticed on acuraparts247.com that the TSX head actually has a different TDC sensor on the intake cam -- 37510-RAA-A01. in this situation, does it need to be swapped for another "PNB" sensor?
__________________
2002 RSX Type-S · Firepepper Red < FOR SALE
2004 Element EX 4WD 5-Spd · Galapagos Green
2005 Cadillac STS V8 · Moonstone Metallic
rsxmachine is offline   Reply With Quote
Old 02-17-2007, 03:43 PM   #19
Froth
Froth's Avatar
Unsure exactly, but it would make sense if indeed it is a completly diffrent sensor.
__________________
Old 02-17-2007, 03:47 PM   #20
rsxmachine
rsxmachine's Avatar
he said it's visually different, and swapped it out with one from a K20A3. but we figured out that his timing chain is off by 1/2 a link so the verdict is still out about the different TSX sensor
__________________
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
