RSX base 32mm Axles for swap??? - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Go Back   K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum > Main K20a.org Forum > General K-series related talk
Reply
Thread Tools
Old 11-30-2006, 08:14 AM   #1
tibbie_03
K20a.org Advanced User
tibbie_03's Avatar
Default RSX base 32mm Axles for swap???
I'm doing a k24/k20 build with 6SP tranny. The motor is going into a del Sol. I heard the RSX base axles are 32mm and can be used for swap axles, they will slide right in. I was told by someone else that they can't be used. I figured you would have to swap the inners for b-series. Anyone know for sure? I don't want to buy the wrong ones. I would buy swap axles but dont have the funds right now. Thanks for any help.
__________________
Vouches: Bocar, SpeedDreamz.com, Rafal, Froth, Big_Teggie, typeSwerx, pb16b, em2typeflex, typerman2001, N.O.B., 1320WhtRex, 2gr84u, txtypes, and jyr3x, mike323, 02ep3si, josh95, k20rDC, nahatch2000, 94ex-vtec, cstyleaccord and much more...
tibbie_03 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-30-2006, 01:16 PM   #2
tibbie_03
tibbie_03's Avatar
Default Re: RSX base 32mm Axles for swap???
cmon someone?
__________________
Old 11-30-2006, 02:50 PM   #3
NAturalDC2
NAturalDC2's Avatar
From what I know you can only use the 36mm RSX axles if you have the JDM ITR 5lug.
__________________
Run what you Brung, and I hope you Brung enough!
I know HIS products, cause I run HIS products.
http://tunerzine.com/
NAturalDC2 is offline   Reply With Quote
Old 11-30-2006, 03:34 PM   #4
Froth
K20a.org Master User
Froth's Avatar
RSX Base axles work on an EG type chassis as they are 32mm but you must swap the inners on them, Meaning the left inner of the RSX Base axle goes to the right side shaft, and vice versa. They work, Don't let anyone tell you otherwise. EP3 axles do NOT work.
__________________
Hondas are like Legos. Cheap, Entertaining, and Easy to put together.
- 2002 New Formula Red AP1.
Read, Comprehend, Post. In that order.
Froth is offline   Reply With Quote
Old 12-01-2006, 09:58 AM   #5
Yasei
K20a.org Basic User
Yasei's Avatar
Quote:
What's different with EP3 axles? Are they different length?
Does anyone know if EP3 Type-R axles are the same as RSX-S? They are both 36mm but I don't know about the length. They do have different part numbers for shaft assys but same for individually available parts...
Yasei is offline   Reply With Quote
Old 12-01-2006, 11:30 AM   #6
Froth
Froth's Avatar
Don't know why, but i've heard several reports of them NOT working.
__________________
Old 12-01-2006, 12:28 PM   #7
tibbie_03
tibbie_03's Avatar
So the base rsx axles will work if you swap the inners. But you cant use the type-s axles and swap the inners on those?
__________________
Old 12-01-2006, 12:37 PM   #8
Froth
Froth's Avatar
If you use RSX-S Axles you need to use B-Series outers to convert them to 32mm. RSX-S Axles are 36mm, RSX Base are 32mm. This is why RSX Base Axles can be used by only swapping the inners.
__________________
Old 12-01-2006, 01:01 PM   #9
tibbie_03
tibbie_03's Avatar
Which is the cheaper way out? Or the best way?
__________________
Old 12-01-2006, 01:20 PM   #10
Froth
Froth's Avatar
Cheaper way out, and the way I would do it is with RSX Base Axles. You can pick up a set for under $200 brand new in some places. www.Rockauto.com has them for around $150 Shipped, but there's a 5 day shipping wait as they're a non-stocked product. They're made by GSP, a company that makes OEM quality replacements. I checked their online product database and GSP Part #NCV21538 and #NCV21547 are their Left/Right Remanufactured axles.
__________________
Old 12-06-2006, 01:10 PM   #11
S-spec
New Member
How much HP can the base RSX axles withstand?
__________________
S Y N O P T I C T U N I N G
Professional dyno tuning
S-spec is offline   Reply With Quote
Old 12-06-2006, 02:06 PM   #12
Froth
Froth's Avatar
I'd venture to say they can hold 180-200hp. But nobody really knows as there's been no testing on them. All you can really do is hope they hold, and if they dont they're cheap enough for me to have another set handy incase they do break.
__________________
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
