Go Back   K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum > K-Series Technical Forum > ECU ,Tuning, Wiring and General K Series Electronics
Reply
Thread Tools
Old 04-01-2006, 09:45 AM   #1
kazino42
K20a.org Basic User
Default Simple wiring harness write-up for EG.
I got my swap done last week, made my own harness with no engine lights. Didn't want to wait and spent the $350. Decide to do a write-up for those who are willing to do their own. If you can read the Hondata schematic , you won't have any problem.
If you can get the sub harness from the RSX to use the connectors, C101 and the E-plug. I was able to get a 02 civic sub harness, used the stock relays, but you can use universal relay, but on the civic connector it's was missing some wires that needed to be added.
So, basically you'll need the C101 to connect to the engine harness, 3 relays and E-plug to ecu. The Hondata schematic is really good, just missing the 2nd O2 and DLC which is in the manual.
For the EG
Once you get the harness made up with the 3 relays.
Unplug the main relay which you don't need anymore. Jump wires 7 and 8, this will let you tap the output from the Fuel pump relay to A7 at the stock ecu harness. Jump 3 to 5, this will let you tap the Ign signal at A25 on the stock ecu harness.
A7 for fuel pump
A25 for Ign signal
D1 for Batt+ (make sure to change the fuse under the hood from 7.5amps to 30amps.)
Main relay looks like this.
8 6 - 2
7 5 3 1
1 Bat+
2 GRN
3 A25
5 IGN
6 St switch
7 Fuel Pump
8 A7
These are the wires I tapped.
E15 - ELD to D10 on stock ecu harness
E22 - Brake Switch D22 on stock ecu harness
E26 - RPM to gauge
E31 - MIL to A13 on stock ecu harness
Engine Harness
3 - VSS - tap it to gauge
7 - FanC -- A12 on stock ecu harness
8 - Alt-L -- A16 on stock ecu harness
16 - Starter -- I solder it to the ignition or tap it to starter wire
18 - Oil pressure -- tap it to gauge
DLC Pin Out
The pinout at the diagnostic port is as follows:
pin 4 (BLK) = chassis ground
pin 5 (BRN/YEL) = LG3 logic ground from ECU pin E3
pin 7 (LT BLU) = "K-Line" (2-way OBDII serial communications line) to ECU pin E23
pin 9 (BRN) = SCS (Service Check Signal) line to ECU pin E29 <--
pin 12 (RED/WHT) = write-enable signal to ECU pin E30 (for rewriting the ECU)
pin 14 (GRAY) = +5V from immobilizer control unit pin 3 (probably for rewriting immobilizer codes)
pin 16 (WHT/RED) = +12V battery voltage (from #9 BACKUP fuse 7.5A)
so another way to do it would be to ground ECU pin E29, and then you should get the CEL flash code as described in the above article.
2nd O2 Pinout
O2 sensor plug
1 2
3 4
1 -- E2 - (WHT/RED) SHO2S
2 -- E4 - PNK SG3
3 -- To A/R Relay (same as the Primary)
4 -- E6 - BLK/WHT SO2SHTCR
Temp and fan switch needs to be wired.
Good luck and make sure to double check. PM if you have any ?
kazino42 is offline   Reply With Quote
Sponsored Links
Old 04-01-2006, 10:04 AM   #2
nikos
Administrator
nikos's Avatar
Default Re: Simple wiring harness write-up for EG.
cool!
I am going to look at this later on tonight and compare my notes
__________________
New K20a.org Phone Number TXT us or leave us a message for anything.
(415) 343- k20a
"A challenge for those who go. A dream for those who stay behind.”
k24a motors for sale every day $1000 shipped
k24a fully Built Shortblock complete $2500 Shipped No core needed
______
Thank you for supporting k20a.org , sponsoring k20a.org and for being a registered user
http://www.wfp.org/<---The World Food Programme is the world's largest humanitarian agency fighting hunger worldwide.
nikos is offline   Reply With Quote
Old 04-01-2006, 10:15 AM   #3
kazino42
K20a.org Basic User
Quote:
Originally Posted by nikos
cool!
Nikos, thanks for your help, too....
It was easier than I expected.
Old 04-04-2006, 10:53 AM   #4
Tommy Ten
K20A.org Sponsor
thanks alot...I am going to try this and maybe post up some pics to have a better understanding
Tommy Ten is offline   Reply With Quote
Old 04-04-2006, 11:19 PM   #5
kazino42
K20a.org Basic User
Quote:
Hey, good luck. Once, you build one, you'll fully understand the wiring. Let me know if you need any help.
Old 04-05-2006, 06:52 PM   #6
pmtrII
K20a.org Advanced User
pmtrII's Avatar
ineed pics???
__________________
ONE LOVE
CHECK OUT MY BUILD!!!
http://www.k20a.org/forum/showthread.php?t=23284
._________________________
|..pmtrII....k24 hatch..........| ||
|..coming soon!!.................||'|";,___.
|_..._...____________=====||_|_|...,]
pmtrII is offline   Reply With Quote
Old 04-05-2006, 06:54 PM   #7
The Dza
K20a.org Master User
The Dza's Avatar
pics would be great.
__________________
AIM=Dm95eg@mac.com
PM SUPRFAST for all swap parts!!!
The Dza is offline   Reply With Quote
Old 07-04-2006, 10:40 PM   #8
joe-c
K20a.org Basic User
joe-c's Avatar
sweet dude now do one with a k24a4 into a ek with a jdm ecu.
__________________
http://sixsigmaracing.com/home SSR/DTR Best Headers Around. Dyno Proven.
ALTERNATIVE AUDIO-Any Brand You Want. Will Beat Any Price.
Will Ship to Your Front Door. 757-285-8767 Cell James Morgan
joe-c is offline   Reply With Quote
Old 09-08-2006, 12:46 AM   #9
janelle
K20a.org Basic User
I took the general plans for this EG harness and made an effort to adapt it to a 4g EF/CRX. I'm looking for feedback from others, and perhaps someone to check it over for errors........so chime in. It's not tested, or even finished.
***see below for updated image/schematic***
I'm unsure of the VSS tap to the speedo. The stock EF cluster would be providing the stock ecu with a VSS signal. Is that what the RSX ecu is looking for, and is the EF signal compatible?
I'm unsure of whether or not the EF main relay terminals are exactly the same as the EG main relay terminals (which I assumed). Can anyone confirm, offhand, that they are?
I'm thinking that fanC to ecu plug position B4 is redundant, since the fan wiring on the EF is stand alone. Confirm?
I'm thinking that the following wiring/circuit items will need to be stripped from the standard EF engine harness:
-back up light wiring
-coolant temp for cluster
-coolant fan wiring
Am I missing anything there?
janelle is offline   Reply With Quote
Old 09-08-2006, 07:57 AM   #10
NHB00R
K20a.org Basic User
see this is what this forum needs.. I already bought a damn hybrid harness and its not even plug and play.. I still have to wire about 14 wires.. that includes 02 sensors.
NHB00R is offline   Reply With Quote
Old 09-08-2006, 08:09 AM   #11
blackwagon
K20a.org Basic User
"I'm unsure of the VSS tap to the speedo. The stock EF cluster would be providing the stock ecu with a VSS signal. Is that what the RSX ecu is looking for, and is the EF signal compatible?"
yes tapping the vss from the cluster will work.
blackwagon is offline   Reply With Quote
Old 09-08-2006, 04:05 PM   #12
janelle
K20a.org Basic User
Thanks for that - one less thing to figure out.
I checked out the helms manual regarding the main relay terminal functions. The ones jumpered turned out to be the same, although the main relay on the EF isn't exactly the same as on the EG. I updated the schematic to include the correct EF main relay terminal description/pinout.
****see update below*******
Does anyone have any information about the back up light wiring. Meaning where it comes off of the engine harness (through the passenger side firewall plugs?)?
Also, what about the fan/thermoswitch wiring. I'm thinking it should be straight forward to pull out of the engine harness. I was wondering why some of the manufacturer harnesses have two ground tabs (little rings to bolt to chassis for ground). I thought the fan wiring circuit only required one ground. Does anyone know more?
I took the info about using fanc w/ kpro from this thread:
http://www.k20a.org/forum/showthread.php?t=8430 ;
It outlines how to use the fanc pin to ground the switching side of a relay.
Here's a link for cluster pinouts - needed for tapping to guage cluster;
http://b16a.honda-perf.org/cluster.html
If someone could supply(sell) me an E plug, I'd make a harness and post up pics.
budget k swap FTW!!!!!!!!!
EDIT: I didn't make a note about wiring up ELD, since I'm in Canada. Position 15 on the E plug would need to be connected to pin B19 @ the ecu harness plugs if you have a car equipped with an ELD (U.S.).
Old 09-09-2006, 09:08 AM   #13
janelle
K20a.org Basic User
Added info for reverse light connection and some info specific to using harness with a type r ecu:
Still missing info on the fan wiring and guage temp guage pin location @ shock tower plug(although you could tap it directly to the cluster). I'll add it if i figure it out.
Old 10-04-2006, 10:52 AM   #14
NHB00R
K20a.org Basic User
sickining thread!!! for making your own harness
Old 10-04-2006, 01:12 PM   #15
janelle
K20a.org Basic User
Quote:
I just got my C101 plug and the DLC hasn't arrived yet, but it's mostly finished. I didn't connect the EF driverside (edit: meant passenger side) shock tower plug(s) yet - will splice them in during install (once I have all swap parts). The second O2 isn't wired (kpro). Worth it for the cost savings and the understanding gained as to how the engine interfaces with your car electrically - in case of future troubleshooting issues.
The second terminal ring (@ the e plug) is for the DLC ground. The fan switch wiring is independant of the swap harness - just ground one end of the plug and tap the other end at the appropriate shock tower plug (which one depends on model) to complete the fan switch cooling circuit. The same goes for the guage coolant temperature circuit.
Thanks to the OP. This helped me save some $$
Old 10-07-2006, 12:18 PM   #16
overlap..
K20a.org Supporter
hey cool post!!!
overlap.. is offline   Reply With Quote
Old 10-23-2006, 03:39 PM   #17
.Chong
New Member
Oh snap, I will be trying to attack this DIY harness soon
.Chong is offline   Reply With Quote
Old 10-23-2006, 04:49 PM   #18
nikos
Administrator
nikos's Avatar
I am about to attach some good info too
__________________
(415) 343- k20a
______
Old 10-23-2006, 05:49 PM   #19
rtmiami
New Member
rtmiami's Avatar
Good info
rtmiami is offline   Reply With Quote
Old 10-23-2006, 06:22 PM   #20
h_turbo
New Member
Great info
h_turbo is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
