Go Back   K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum > K-Series Technical Forum > Drag Racing / Road Racing
Reply
Thread Tools
Old 03-24-2006, 06:55 AM   #1
Matador
Punishin' Bitches
Matador's Avatar
Default Official Registry: 1/4 Mile Quickest All Motor Times On DOT Street Tires
Hey guys im trying to devise a List of all the All Motor Cars Running the Quickest Times On Street Tires. If you have a Time you Want to Submit Please Submit it to me In this Format So I can Keep It in Order.
Username - State / ET@MPH / Chassis/Motor Type (k24,k20,k20R, Etc. + Modifications) / Weight w Driver / Tire Size
I have now decided they cutoff time is 14.0 For The DOT Street Tires Registry.
  1. Jeremyinlinepro - VA / 11.32@122 / EG K20 Modified / 2350lbs / 225/50/15 BFG Drag Radials
  2. Allmotorb18c - NJ / 11.56@120 / EG K24 modified / 2100lbs. / 225/50/15 BFG drag radials
  3. Toy - New Zealand / 11.66@121MPH / EK Civic / Built K24 / 2325lbs / M&H 15 X 26 X 10.5
  4. G AE82 - AUS / 11.67 @ 116.55 / 85AH K20R 70MM TB +RBC/H/3 inch exhaust + K-Pro/ 1750lbs / 215/60/14 BFG Drag Radials
  5. Toy - New Zealand / 11.89@115.08MPH / EK Civic / Built K24 / 2325lbs / M&H 15 X 26 X 10.5
  6. Garenty 11.93 @ 115.7MPH 1.68 60ft / 1996 EK / 2365lbs w/driver / K-24 "JE pistons" / stock rod's & bottom end with type-s head "not ported" / IPS K2 cams / supertech springs / prb intake / R-Crew header / K-pro, 23.5/08/13 MH's.
  7. Tainted - NJ / 11.94@114 / "De-stroked" k24/k20 head/ R-crew header/75mm TB/3"exhaust / 2365lbs / 225/50/15 BFG DR's
  8. honda_b_blastn - AUS / 11.95@119/EG HB K24 modified /2099lbs/ 205-50-15 m/t's street radials
  9. cxcivic - FL / 11.96@117 / CRX k24/k20 Head+Cams/ DTR 4-2-1Header / Kpro + street tune / 2000lbs / 225/50/15 BFG Drag Radials
  10. 1fstEP3 - VA / 11.96@116 / '99 EK hatch / K24 Modified / 2360lbs / 225/50/15 BFG drag radials
  11. Palma4dr - NJ / 12.1@113 / 92EG k20a2 I/R-crew Header/ 3inch + Kpro Tuned / 2190lbs / 225/50/15 M/T Drag Radial White bubble A.K.A La Greka
  12. spoonpun - NJ / 12.21@115mph / Eg k24/k20 Rcrew Cams/ Rcrew Header / Kpro/ 2360lbs / 225/50/15 M/T drag radials
  13. honda_b_blastn - AUS / 12.36@111mile/Eg hatch jdmk20 SSR header,CAI,kpro/2165lbs/ 205-50-15 m/t's street radials
  14. Palma4dr - NJ / 12.3@111 / 92EG k20a2 I/R-crew Header/ 3inch + Kpro Tuned / 2170lbs / 205/50/15 BFG Drag Radials
  15. sibubble921 nj 12.4 @111mph 2245 lb k20z1 rbc/ manifold /hytech replica header/ 3in piping/ yosolo tuned/ kpro mt drag radial 205 50 15
  16. WTFisaK24 - NJ / 12.4@115 / EK / K24/K20Modified / Rcrew header, Rcrew Cams, 3" Ex, RBC, Kpro / 2220lbs. / MH Racemaster 235/60/15.
  17. Kon - IL/ 93 civic hatch/ 12.4 @ 113/ K24 modified, RBC, Rcrew header, IPS K2, Kpro tuned/ 225,50,15 BFG Radials
  18. k20aCRXSI: '95 Civic EX: VA: 12.5 @ 110 @ M.I.R: stock k20a2 "Treblic tuned" on Kpro, RBC, R-Crew Header, PUMP GAS. 225/50/15 BFG DragRadial
  19. mr_vtec- Australia / 12.5@109mph / DELSOL k24/k20 r crew headers, CAI, kpro / 2450lbs / 205/50/15 m/t's street radials
  20. Hondafreak - WA /12.5@108 / 93 civic k24a2 TWM ITB's/IPS K2 Strokers/DTR 4-2-1 + Kpro / 2350lbs / 225/50R15 BFG Drag Radials
  21. dnrprojectsvp - CA / 12.6@113 / EK hatch / k20head/K24 IPS KME's/DTR Header/3" Exhaust + Kpro Tuned / 2365lbs / BFG drag radials 205/50/15
  22. #2 - NJ / 12.6@109 / 95EG K20a2 I/R Crew Header/E + kPro Tuned/ 2350lbs / 205-50-15 BFG drag radials
  23. yosolo - NJ / 12.64@108 / EG K20a2 I/DC Sport TSX Header/E + AEM Tuned/ 2324lbs / 225/50/15 BFG Drag Radials
  24. Matador - VA / 12.70@111 / EG K20R - I/DTR Header/E Kpro + Tuned/ 2275lbs / 195-50-15 AVS ES100
  25. sleeper6speg - NC / 12.70@109mph / 93 EG Hatch k20a2/custom intake w/ velocity stack/hasport header/apexi n1 exhaust + k-pro street tuned / 2150lbs / 205/50/15 bfg drag radials
  26. JDM96specCTR - NY 12.70@108 93 cx k20a2 / rcrew header / kpro / lsd / rbc / street tune / 205/50/15 drag radials
  27. xcell - NC / 12.7@108 / EF K24/k20a2 Hondata IM Gasket/CAI/Hasport header/ 2.5 Exhaust + Kpro Street tuned / 2100lbs / 225/45/17 BFG Drag radials
  28. mrk20a - AUS /12.7@107.5MPH EG Hatch /JDM k20a/dc sport headers/CAI/KPRO/2300lbs (i think) 205/50/15 m/t street tyres
  29. yosolo 2nd Car - NJ / 12.78@108 / DC2 K20a2 I/R Crew Header/ R Crew Cams / 3" E + KPRO Tuned / 2545lbs / 225/50/15 BFG Drag Radials
  30. Crank - CA / 12.82 @107 / Honda Fit / Stock K20A CAI/Custom 4-1 Header / 2550lbs / 205/50/15 Bridgestone Potenza Street Tires
  31. hyperev - Manilla12.83 @ 107 / 4dr ek body cf hood and trunk 2650lbs with driver / jdm 6 speed tranny / hondata kpro / web cams/wiseco ots pistons / custom header / k20/k24 itbs / advan neova ado8 225 /45 /17
  32. spoonpun - NJ / 12.8@106 / EG k20a2 / I/DC TSX Race Header/E + RBC Manifold / 2508lbs / 225/50/15 BFG Drag Radials
  33. Z10 - AUS / 12.8@106 / 92EG k20aR I/DTR 4-2-1 Header/E 3inch + Kpro Tuned / 2200lbs / 205/50/15 BFG Drag Radials
  34. xtcat8k-VA / 12.8@105 / EK K20A I/RCrew header/P.I.M.P./E + Kpro Tuned / 2495lbs 205/50/15 BFG Drag Radials
  35. allmtrallday - CA / 12.9@112 / EG HB K20R DTR Header + Tuned / 2200lbs / 205/50/15 Falken Azenis
  36. Midnight Auto - NY / 12.9 @110 /CX HB Stock K20A2 I/DC TSX header/K-Pro + Street Tune / 2xxxlbs / 225/50/15 BFG Drag Radials
  37. HotWheelz - Canada /12.9@109.5 / EK Hatch K24a2/R-Crew cams/custom 4-2-1/CAI/KPRO /2450lbs 205/50/14 BFdragradials
  38. WTFisaK24 - NJ / 12.91@105mph / EK k24/k20 Rcrew Cams/ Rcrew Header / Kpro/ 2120lbs / 195/50/15 Yokohama Avs Es 100
  39. SPL Dan - FL / 12.91@109 / 00 Si EK / K20A2 , I/H/2.5 Exhuast , RBC , Kpro / 2xxx lbs / 225/50/15 MT ET Drag Radial
  40. DAT-DUDE-CH - NJ / 12.92@104.74 / k20 eg coupe / RBC IM / r-crew header /2512lbs / 225-50-15 bf
  41. CRXBart - OH / 12.979@109.62 / 89 CRX Si/K20R DTR 4-2-1, 2.5" thermal exhaust, custom fabbed CAI, tunned Kpro / 2XXXlbs. / 205-50-15 Azenis RT615
  42. mightbetotaled - VA / 12.9 @108 / 94 EG k20a2 I/2.5 Exhaust+ Kpro / 2xxxlbs / 225/50/15 BFG Drag Radials
  43. R@mon - FL / 12.90@107 / EG K20a2 I/dtr4-1/E + IPS k2's + Kpro Street Tune / 2500lbs / 225/50/15 BFG Drag Radials
  44. 1qwikef - MD91 crx si /k20a2 W rbc i/h and 3"E on Kpro base map. 2160 with driver, 205-50-15 falken 512 all season tires. 12.92 @ 109.57 2.076 60ft
  45. Timaa66 - MD / 12.95@109mph / EG hatch /12.5 CR k24 with k20 head stage 3 blueprint cams / 2315lbs / 205-50-15 Azenis RT615
  46. Powerovanyc - NY / 13.0 @ 108/ 94 Eg Coupe, Ihe 3" Exhaust, Rbc, Kpro Tuned/ 24xxlbs/ 205/50/15 Bfg Drag Radials
  47. Sicksilver_ep3 - IL / 13.00@107.98 / EK / (K20a, I/H/3in RBC Blueprint cams 246whp 173wtq) / 2525lbs / 225 /50/15 BFG's
  48. Froth - MD / 13.01@105.74 / 93 EG Si / K24/K20 Frank - I/H/E Kpro - Tuned / 2450lbs / 225/50/15 BFG Drag radials
  49. 92 EH2 - NY / 13.05 @104 / DX HB Stock K20A2 DC TSX header + w/ K-Pro + Street Tune / 2xxxlbs / 225/50/15 BFG Drag Radials
  50. AK40Tyler93 - MD / 13.15 @108 / 95 eg hatch / k20a2 cold air, rbc/r crew /custom 3 inch/ k-pro / 2450 with driver / 225/50/15 G forces.
  51. Marc P - FL / 13.1@105 / EG K20a2 I/E/H/KPRO / 2460lbs / 225/50/15 BFG Drag Radials
  52. 1999_ITR - Toronto / 13.10@107.19 / DC2 K20A I/H/E / K-Pro street tuned / 2667lbs / 205/50/15 BFG Drag Radials
  53. rayb3nus AUS - 13.1@104mph / k20z1 bone stock /2100lbs / tdm headers / 3 inch exhaust / custom cai / stock suspension / bridgestone re001 195/50/15
  54. Tony4380 - GA / 13.11@107.50mph / EF K20A2 stock with I/Hasport H/E and kpro air-fuel tune / 2180lbs / 225/50/15 BFG Drag Radials
  55. allmtrallday (beater) - CA /13.1@105 / 94 EG civic k20a2 RBC/DTR 4-2-1 + Kpro + untuned / 23xxlbs / Falken RT-615 205/50/15
  56. AK40Tyler93 - MD / 13.15 @108 / 95 eg hatch / k20a2 cold air, rbc/r crew /custom 3 inch/ k-pro / 2450 with driver / 225/50/15 G forces.
  57. blubyu-nj/13.2@104 /eg stock k20a2,r crew header,rbc,3inch exh,and yosolo kpro tune/2366lbs/ 205/55/15 mt streets
  58. Marc P (Keith076 owner)- FL / 13.29@103 / EK(CW) K20a I/H/E/KPRO / 2550lbs / 225 /50/15 Hoosers
  59. 2000r#0283 - FL / 13.30@103 / EG k20a2 I/DC Header + itr stock ecu / 2400lbs /205/50/15 VFG Drag Radials
  60. ninetails - FL 13.3 @107mph / 2400 lbs / k20z3 w/z1 tranny rcrew headers 3inch exhaust, spoon tip, kpro tuned by m@se hankook ventus 205 50 16 street radials
  61. sleeper6speg - NC / 13.366@106.44mph/ 93 EG Hatch k20a2/custom intake/hasport header/apexi n1 exhaust/k-pro street tuned 2xxxlbs / 205/55/15 bfg traction t/a
  62. John_civic - CANADA / 13.40@105 / EG K20Z1 Kpro,Rcrew header, Skunk2 Exhaust / 22xxlbs / 205/50/15 Azenis
  63. 93cx / 13.43 sec @ 107 / DC4 K20R - Intake / Rcrew header / Untuned K-pro / 2250 lbs - 205-50-15 AVS ES100
  64. boosted98acura - PA / 13.471@106.92 / DC4/K20a2 bolt-ons 223whp / 2600lbs w Driver / 205-45-16 Nitto Neo Gens
  65. KESE-KMODRSX - NJ / 13.48@101.44 / RSX Type-S DC5 K24a4(head/Block) / 2900lbs / 225/50/16 Hoosier DOT Drag Radials
*Cut Off is 13.50 People*
ALSO PLEASE DON'T PM ME YOUR TIMES, POST ON THIS THREAD, AND WHEN I OR THE OTHER MODERATORS ARE NOT BUSY WE WILL UPDATE IT!
If you guys have any suggestions on how maybe to list this better feel free to chime in.
Also please people, if you want your times entered in this registry please please please follow my format... give me your exact perimeters that i am asking for you guys to provide me with, if not then you will not be entered until Done so.
__________________
Bolivian k20aMember#1 Punshin' Girls In the A-Hole
Just Killing The Competition
K20R Motor
12.70@111 On AVS ES 100's *Real Street Tires*
Matador is offline   Reply With Quote
Sponsored Links
Old 03-25-2006, 09:55 AM   #2
allmtrallday
NOR*CAL
allmtrallday's Avatar
Default Re: Official Registry: Quarter Mile Quickest All Motor Times On DOT Street Tires
neil- CA- eg hb k20r tuned, dtr header, custom intake- 12.9@112mph- 2200 with driver then. on 205-50-15 falken azenis.
__________________
Coming back.
allmtrallday is offline   Reply With Quote
Old 03-25-2006, 12:11 PM   #3
Matador
Punishin' Bitches
Matador's Avatar
Good time. How much power are u making?
__________________
K20R Motor
Old 03-26-2006, 05:11 PM   #4
Midnight Auto
K20a.org Basic User
Midnight Auto's Avatar
12.9 @110 /92 CX HB Stock K20A2 w/ K-Pro, DC TSX header, Custom Short ram Intake/ 225/50/15 BFG's
__________________
MIDNIGHT AUTO
BITS RACING
790A Marconi Blvd.
Copiague NY 11726
631-270-4540
Midnight Auto is offline   Reply With Quote
Old 03-26-2006, 05:14 PM   #5
xcell
New Member
12.7@108 with k24/k20 on 225/45/17 BFG's.
xcell is offline   Reply With Quote
Old 03-26-2006, 06:37 PM   #6
JDM96SpecCTR
K20a.org Master User
JDM96SpecCTR's Avatar
jdm96specctr NY- 13.21@105 k20a2 eg - R-crew header - 5spd tranny - kpro - 2330 lbs - 205/50/15 bfg drags
__________________
TEAM EXiT www.myspace.com/team_exit
Midnight Auto - www.midnightautonyc.com
EvaUnit01: nope, the american dream is a fully finished car with a K24/k20 setup.
JDM96SpecCTR is offline   Reply With Quote
Old 03-26-2006, 07:24 PM   #7
mightbetotaled
New Member
mightbetotaled-VA 12.9 at 108, k20a2 94 cx, 201whp 150tq, Aem coldair, dc tsx header, custom 2.5 with flowmaster, kpro, 225 50 15s bfg drags
mightbetotaled is offline   Reply With Quote
Old 03-26-2006, 07:38 PM   #8
R@mon
K20a.org Basic User
R@mon -FL / 12.90@107 / EG K20a2 dtr4-1, ips k2's / 2500lbs / 225/50/15 BFG
R@mon is offline   Reply With Quote
Old 03-26-2006, 07:55 PM   #9
Matador
Punishin' Bitches
Matador's Avatar
Quote:
Could you go into more detail what your setup consisted of? What Chasis also?
Quote:
What Year EG?
Quote:
Were you tuned?
Quote:
Were you tuned?
__________________
K20R Motor
Old 03-26-2006, 08:18 PM   #10
JDM96SpecCTR
JDM96specCTR NY- 13.21@105 k20a2 eg - R-crew header - 5spd tranny - kpro - 2330 lbs - 205/50/15 bfg drags
93 cx hatch, street tuned
__________________
Old 03-26-2006, 08:24 PM   #11
R@mon
K20a.org Basic User
Quote:
Originally Posted by Matador
Were you tuned?
only the airfuel was tuned
Old 03-27-2006, 08:34 AM   #12
Midnight Auto
K20a.org Basic User
Were you tuned?
Street tuned
__________________
MIDNIGHT AUTO
BITS RACING
790A Marconi Blvd.
Copiague NY 11726
631-270-4540
Old 03-27-2006, 12:54 PM   #13
Matty
K20a.org Basic User
Ah what the hell. Slowest swap evarrr...
Matty - NZ / 13.916 @ 97.53 / '97 EK4 hatch / K20R / short intake, open 4-1 Pro1 header, otherwise stock / over 2600lb / 205/50/15 Toyo RA1s
No idea why my trap speed was so low. Another guy I raced was making 100-101mph passes, I could be sitting RIGHT beside him all the way, even shifting into 5th, and I'd still show as a 98mph pass. Someone hates me.
Matty is offline   Reply With Quote
Old 03-27-2006, 01:28 PM   #14
Matador
Punishin' Bitches
Matador's Avatar
Updated.
__________________
K20R Motor
Old 03-27-2006, 02:39 PM   #15
1fstEP3
K20a.org Basic User
1fstEP3 - VA / 12.18@114 / '99 EK hatch / K24 / 2360 lbs / BFG drag radials 225/50/15
__________________
1995 Honda Civic HB 10.49@129 All Motor Street
2002 Civic Si K20A 12.97@103 All Motor Street
1fstEP3 is offline   Reply With Quote
Old 03-27-2006, 03:23 PM   #16
Matador
Punishin' Bitches
Matador's Avatar
Updated.
__________________
K20R Motor
Old 03-27-2006, 09:41 PM   #17
JDM96SpecCTR
Updated.
dam i dont get included on the list??
__________________
Old 03-27-2006, 10:05 PM   #18
Matador
Punishin' Bitches
Matador's Avatar
Updated!
__________________
K20R Motor
Old 03-28-2006, 10:58 AM   #19
allmtrallday
NOR*CAL
this was over a year ago. 220whp 153 ft lbs. bone stock k20r with dtr header and k pro.
__________________
Coming back.
Old 03-28-2006, 11:23 AM   #20
Matador
Punishin' Bitches
Matador's Avatar
Interesting.
__________________
K20R Motor
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
