vacuum hose 2 brake booster from intake manifold (RBC) - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 02-15-2013, 10:44 AM   #1
Sancho
K20a.org Basic User
Sancho's Avatar
Default vacuum hose 2 brake booster from intake manifold (RBC)
I bought a shaved RBC , now the problem is that i dont have the original hole anymore where the vaccum hose that runs to the brake booster. ofcourse need to have this with my spoon calipers or any kinda calipers else it wont brake.
i was thinkin to use the little 'thingy' (connection) on the left side on the intake manifold that leads to the engine (ventilation?)
it is not as big like the original brake booster hose connection on the intake manifold (that i dont have because it's shaved )
should I do it like this or..; what u guys think,
I want to split it , 1 to my engine and 1 to my brake booster.
do i need that hose from the intake manifold to the engine (ventilation) ??
example, the cross is what i dont have,
the circles are how i want to run it!
Sancho is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-15-2013, 11:16 AM   #2
SickSilver_ep3
NA EK love
SickSilver_ep3's Avatar
Default Re: vacuum hose 2 brake booster from intake manifold (RBC)
drill a hole and tap it on the bottom.. put a barb in there and hook it up
__________________
96 midori EK All Motor / Prayoonto Racing
Build thread/ Prayoonto 2.7 9.65 @ 142.4
http://www.k20a.org/forum/showthread.php?t=94487
SickSilver_ep3 is offline   Reply With Quote Quick reply to this message
Old 02-15-2013, 12:07 PM   #3
Sancho
K20a.org Basic User
Sancho's Avatar
Quote:
hmm but then I have to demount my intake manifold again to be sure nothing fals into my engine. rather try it like i suggest above, u think it wont work?
whats the other barb that ive circled
Old 02-16-2013, 06:35 PM   #4
preston
Lifetime Member
preston's Avatar
that other barb you've circled is supposed to go to the port on the front of the water pump housing. you could use that one, but you'd have to run a small catch can from the water pump housing then. where is the hose going that's up by the injectors?
__________________
Vouches:
Scott@HPT, K-serious-Eg, 93civichb, eg6k20a2, ReDeMoN, JDMciv'bomb, Clean EH2, Bodyman, BlackNDecker, mr fobster, filipinop1405, importracer2123, 1320whtrex, justtheshop, negrok20r, rexthermal, darqnez, Acurazor, Dube Built.
http://www.hybrid-racing.com/
http://donkeypowerinjection.com/
http://afhkparts.com/
http://wire-worx.com/
preston is offline   Reply With Quote Quick reply to this message
Old 02-16-2013, 10:52 PM   #5
Sancho
K20a.org Basic User
Sancho's Avatar
Quote:
isnt that barb going to the pcv valve?
i'ff it's the water pump housing it ejects water then?
Think the example pic i'm using the guy has taped a hole underneath the intake like Silver sugessted
Old 02-17-2013, 05:04 AM   #6
preston
Lifetime Member
preston's Avatar
it's an oil recirculation. after i took my intake manifold off a couple years ago and saw the oil film laying in my manifold i said eff this. not gonna have dirty oil air getting sucked into my engine.
so the pic you posted isn't your bay or manifold?
__________________
Vouches:
Old 02-17-2013, 08:42 AM   #7
Sancho
K20a.org Basic User
Sancho's Avatar
it's not my bay, I'm starting my swap next week ,
Old 02-17-2013, 08:46 AM   #8
brakaT
K20a.org Master User
brakaT's Avatar
X2. That's what's done on my RRC
__________________
2000 CW JDM RHD ITRx
Neighbourhood Troll
brakaT is offline   Reply With Quote Quick reply to this message
Old 02-17-2013, 08:48 AM   #9
Sancho
K20a.org Basic User
Sancho's Avatar
Quote:
hmmm i have a hondata intake gasket and used honda bond, it's really good in place, first gona try with the little nipple on the left from the intake manifold!
Old 02-17-2013, 08:50 AM   #10
brakaT
brakaT's Avatar
If the engine is out of the car, it should still be pretty easy to tap it. Do it right the first time. Post a pic of your manifold.
__________________
Neighbourhood Troll
Old 02-17-2013, 09:23 AM   #11
Sancho
K20a.org Basic User
Sancho's Avatar
so where wouldt be the best place to dril?
I still have the nipple from my old manifold, this one is a ported RBC
Old 02-17-2013, 01:50 PM   #12
preston
Lifetime Member
preston's Avatar
right where my an fitting is. if your not taking the manifold off the engine to drill and tap it then use plenty of grease on the drill bit to catch all the shavings.
__________________
Vouches:
Old 02-18-2013, 05:17 AM   #13
R-Civic
K20a.org Advanced User
R-Civic's Avatar
Or drill and tap the hole under good vacuum..(ja een stofzuiger ofzo)
But really the best way is to just take the manifold off...if you dont want to take any risk off any depri falling in the engine. a messed up engine is worse then a redoing some honda bond.
Now hurry-up, still waiting on some belgium action.
R-Civic is offline   Reply With Quote Quick reply to this message
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
