K24a2(rbb) vs. k20a(rsp) head
2 reading
84K views 64 replies 20 participants last post by  AWOC
#1 · (Edited)
I thought i would start a new thread for searching purposes and for any future builds out there.
This is my build thread with the k24a2 head http://www.k20a.org/forum/showthread.php?t=75424
Well after the setup was dyno tuned it became apparent that something was not right as the motor was not putting down the expected power and the vtc was all over the board and wanting 40deg. Vtc all the way to redline. Which is how this thread started http://www.k20a.org/forum/showthread.php?t=77640. After some trouble shooting and coming up empty handed. There was only one thing left to do. Swap the head!
I was able to pickup an rsp head from morgan at synapseturbo.com. Threw in some supertech valves as the head was new and i didnt want to use the orginal tsx valves that came in the longblock.
Well i installed it last week and morgan was able to get me in for a retune. Needless to say i very happy with the out come. The motor picked up 20+hp and is ready to be pushed further as my rev limit is only set to 8000. I plan to swap out some minor bolt ons and tune on e85 as i am running 93 oct.
Here is the motor with k24a2 head
#5 ·
Is there a dyno graph of this car? The numbers weren't my only concern. The way the the power just flat lines at 6500 is what wasnt making any sense. Once the new graph is posted it will be very apparent. This head change the game on what this motor is capable of. Mind you it's an OEM stock port(untouched) head!
#7 · (Edited)
And to add to the above if im not mistaken the blueprints are a bigger cam. I could have dropped bigger cams in my setup and probably make more power, but i dont think it would change the curve. It would probably just move it up. By swapping the head i unlocked power that was already there. That guy might benefit the same.
#17 · (Edited)
'05
The RBB should have never been made LOL. Good thing their mistake is easily fixed :)
The power gain should not surprise anyone at all. The RSP is in a class of its own compared to the RBB. In the flow areas that matter, the RSP is 20-35 cfm better...so 20hp is realistic. CFM aside, it has a better port shape all around. Though recently I saw suggestions here that we need to start flowing heads below .150 lift :blur: Here is a good first example...maybe I could have a few hundred customers share their examples. '04of that theory being put to rest.
i wouldn'te say i was surprised, more glad to figure out what was causing the poor readings on the dyno.
Are they around 500ish?
the head cost 1100. And the last i checked which was a few months ago there was only one in the u.s.
#11 ·
The power gain should not surprise anyone at all. The RSP is in a class of its own compared to the RBB. In the flow areas that matter, the RSP is 20-35 cfm better...so 20hp is realistic. CFM aside, it has a better port shape all around. Though recently I saw suggestions here that we need to start flowing heads below .150 lift :blur: Here is a good first example...maybe I could have a few hundred customers share their examples of that theory being put to rest.
#16 ·
When Joe McCarthy posted that I immediately thought of you and how you might respond....care to elaborate further? Any thoughts on where in the RPM range < 0.150 lift is happening?
This post has been deleted
#39 · (Edited)
back from the dead with another test on a different motor
2008 stock TSX (longblock) with:
RRC IM, Injen Intake, P2R TB spacer, Header & exhaust
before stock RBB head with stock valves (+1mm oem intake)
after RSP with Ferrea 6000 (std size) valves. Gained 19whp up top! fyi we were able to eliminate the tq dip from 5000-5700 with a stepped intake w/velocity stack. Getting that to fit is another story LOL
#52 ·
Thanks for posting, Greg. Love this kind of stuff. I still refer back to the original comparison in this thread often. Helped me in the decision to buy one of Luke's heads. And now another one... :up:
Help me on this one. Was this elimination done after these graphs, before or between? And what size/lengths did you step between? :huh:
#41 · (Edited)
So that's basically the difference between the worst flowing OEM head and the best, right? (excuse my noobness lol) on a mild setup with stock compression , only rev'ing to 7400 when the head will flow to 9k
Fixed & yea that sums it up... I'll add it appears there could be a restriction in the intake track that rears its head around 6500 to redline according to the map sensor. Probably good for a few more ponies. It's not the actual intake either
#45 · (Edited)
I mentioned earlier in the thread Larry and/or Luke alluded to the fact they've seen castings vary from bad to worse. Another friend mention he thought rbb castings got worse after 06. The built motor was running an older head. Maybe just coincidence or maybe those guys are right. On the stock motor it Could also be a combination of ferrea 6000 valves? Who knows
Power dip on the KME motor? Are you refering to the low cam? I mentioned ealier we load the dyno at a higher rpm? If so that's so the car can avoid pinging (pump gas + 12.5cr). Ignition timing and vtc is also conservative to help reduce the chances.
Same intake tested on the stock car was tested on the 2.4 kme car & did this
here is a graph from Allmotor98's K24 (12.5 IPS KME RRC DTR header) No tuning - I bet we could have picked up some more power up top with tuning & adjusting vtc
FYI the a/f dipped real rich at 6750 (hence the same power)
Edit: You can also see here one pull the load point was 3250 and the other pull was 3500
