#1 |
K20a.org Advanced User
First off everything is still in the car and located in central nj.
Car is currently at the shop and won't have individual pictures cause I will remove items as they are sold.. Don't want to part the complete car out all at once because I won't have the time. I'll do it piece by piece as items are sold. I'll get more pix upon request. Motor blew on the dyno yesterday made 315whp with 100 shot lol. Here's list of what I got so far. I will post w.e. pix I have a.t.m. In a few hours. PRICES PRETTY FIRM. SHIPPING AND PAYPAL EXTRA!!! ONLY WAHT IS LISTED IS FOR SALE!!!!!! TEXT ME 9084871848 Text ONLY I ignore calls 9084871848 92 cx shell gsr rear disc new viper LCD alarm and remote start polk audio door speakers sony head unit carbon fiber duck bill skunk 2 lca sk2 fron upper control arms *rear camber kit prothane rear trailing arm bushings walboro 255 fuel pump welded in hasport k mounts included shell 1500$ S2k ap1 *cluster with pig tails. 79k *250$ 300$ with speedo heeler k20z1 oem tps sensor 40$ k series karcepts iacv block off 20$ shipped brand new Shift box with karcepts shifter plate 150$ Eg/ek gun metal C pillar 40$ Nitrous express Nx wet kit 10lb filled bottle liquid filled gauge . Single fogger shark nozzle 100hp jet complete *everything you need 450$ 15 inch rpf1 Wheels with new hankook 195-50-15 tires 500$ 225 50 15 Goodyear Bf's drag radials 250$ Eg Carbon hood fresh 300 $ Eg hatch Carbon hatch with 50/50 tail lights 300$ Eg engine Full harness's from engine to k-pro 300 $ k20z1 type s full rocker assembly 150$ K20 Type s injectors50$ K20 Alternator & aem aluminum silver under drive pulley 100$ K20z1 Trans 4.7 final mint with vin legit *800$ Stock k20z1 Clutch and flywheel 100$ Legit with Vin K20z1 long block with blown rod&piston. No springs retainers or cams *200$ K20 skunk 2 stage 2 Cams with k20z1 cam gears used only for 1 dyno session 500$ K20z1 Type s stock springs and retainers 100$ HIGH QUALITY security chain 12ft to chain you vehicle with (Enuff to chain your trailing arm to a telephone pull) *heat treat high quality pad lock (similar to kryptonight chain/lock) 150$.Just the *Lock alone cost me 150$.* Polished extended lug nuts 30$ K20 Type s iacv iac valve 40$ K20 v-tec solenoid 40$ K20 type s map sensor 25$ K20z1 stock header 25$ Bosh dual terminal battery full size 800cca 50$ K20 Aem aluminum power steering pulley 25$ K20z1 oem intake manifold 40$ Blox eg/dc will fit ek also 1 piece coil overs 10k 12k spring rate. Less then 1000 miles 500$ Eg/ek skunk 2 rear strut bar 75$ ![]() ![]() ![]() ![]() ![]() ![]() Last edited by greenhatchy; 09-27-2012 at 06:20 AM.. Reason: updated... |
| Sponsored Links | |||
Advertisement | |||
#2 |
The Professional
Interested in the wheels but you need to read the rules and provide pics with a namecard for all this stuff.
__________________
K20a2 - 239/164 IMW tuned (Derek) with svm 212's. Need 70mm t.b., port matched i.m., and 3.5" intake badly. Autofair Honda>Majestic Honda. |
#3 |
K20a.org Basic User
im interested in the hood and hatch willing to work out a deal?
#4 |
K20a.org Basic User
At least a general pic of car would be nice with name card. interested in asr polished brace.
#5 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by greenhatchy; 09-10-2012 at 11:45 AM.. |
#6 |
New Member
Very intrested in the K20z1 stock cams K20 Super tech valve train and springs retainers and seals how much for both shipped to 30040 and how many miles are on the cams thanks
#7 |
K20a.org Basic User
Bump for you
#8 |
bummmmmmmmmmmmmmmmmmmmp
#9 |
K20a.org Master User
Payment sent for the Kpro and injectors
__________________
135 ├┼┼┒ 246R ✫Bottle fed K20A swapped 93 hatch✫ |
#10 |
K20a.org Basic User
pm'ed
__________________
92 civic si captiva blue 86x89mm b18c ** sold** 00 ITR #272 fbp k24a2 6spd |
#11 |
#12 |
new parts listed will take more pix this evening
#13 |
Updated bump.
#14 |
Bump for every single window shopper i had pm me text and and just bs.. Why waste my time i dont get it
#15 |
Bump for a good seller!
__________________
#16 |
New Member
Hey man do you still have the fuel lab regulator. If so how much shipped to texas 78596.
#17 |
Text me 9084871848
People stop window shopping and lowballing |
#18 |
New Member
Payment sent for k20z1 spool valve. 40 shipped, thanks
#19 |
Will have everything shipped out today
#20 |
bmmmmmmmmmmmmmmmmmmmp
| Bookmarks |
| Thread Tools | |
