LSThatch/Blacktyper01 Turbo V6 Hatch build - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Go Back   K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum > K-Series Technical Forum > J Series V6 Swap Forum
Reply
Thread Tools
Old 05-03-2012, 07:36 PM   #1
LSThatch
New Member
LSThatch's Avatar
Default LSThatch/Blacktyper01 Turbo V6 Hatch build
Pardon the huge first post, just want to catch everyone up on the build thus far. Originally posted this on J32a.com:
I completed my first stock J32A2 swap in my brother's car a few years ago ... I posted a few pics of the cowl hood on j32a ... now it's our turn ;)
blacktyper01 and I have combined our efforts to produce a turbo v6 eg hatch. All work (fab, wiring, tuning, etc.) is done by either him or myself with some back up assistance by any extra hands that happen to stroll through the shop.
A little back story ...
car started it's life with us a few years ago when we fabricated/installed a built LS/VTEC turbo setup in it for a customer:
- 10pt cage
- 5pt harnesses
- battery relocation
- parachute mount
- dual Bosch 044 pumps
- Precision intercooler core with custom end tanks
the engine had a catastrophic failure at 40psi of boost and the owner sold the chassis and part of the turbo setup to us.
After the first few weeks we decided to install a bone stock J32A2 swap (M/T) and ended up with a best track pass of 12.53 @ 109.6mph at our local track.
Then we decided to install AEM but (since our local track closed down) we have been unable to run it. We changed over to an auto motor/harness and cleaned up the wiring a bit to ease the use of the plug-n-play EMS system (darn cam and crank sensors):
We also cut down the water neck and customized the radiator to make room for our future plans ;)
The idea was to see what we could get out of the car on the stock motor and AEM. However, being as impatient as we are (and that fact that our local track got closed down) we decided to just go ahead and turbo it ... here's the first teaser pic (the turbo's a bit heavy so, yes, we used a seat belt and engine hoist to hold it in place, lol):
We were thinking about custom fabricating an IM but, in the interest of time, we went with a port & polish of a stock A2 IM, plus port matching the inlet to a 75mm Edelbrock throttle body:
upper IM being all cleaned up ... we removed the butterfly system and sealed the EGR port too.
the beginnings of the turbo manifold:
Making the collectors:
Test fitting collector on manifold:
Turbo mounting bracket fab:
Catch can:
Fuel rails (-8 in, -6 out ... FIC 1000cc K-series injectors):
Front turbo manifold fab:
some more progress:
rear manifold:
-8an fuel supply line:
wastegates (2x Tial 44mm):
Should finish up oil feed line, downpipe, and hood tomorrow ... then we'll be taking it out for a spin ;)
LSThatch is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-05-2012, 06:59 AM   #2
LSThatch
New Member
LSThatch's Avatar
Default Re: LSThatch/Blacktyper01 Turbo V6 Hatch build
progress before the first drive:
downpipe:
hood cutting:
hood closing and completed setup:
Took care of all this yesterday ... got it started up on AEM and took it out for part-throttle tuning last night. Everything looks great besides an overheating issue caused by our puny fan ... SPAL 13" 1700cfm unit is on the way
Old 05-13-2012, 06:12 PM   #3
LSThatch
New Member
LSThatch's Avatar
So, ... we threw a SPAL 13" 1700cfm unit on there and it's working flawlessly ... guess an extra 1050cfm did the trick, lol.
Took it out and street tuned it on 8psi ... runs great and has tons of torque!
Took it to the track this past Friday and did a couple 11.6 passes @ 121 mph with the clutch slipping or the tires (24.5x9" slicks) breaking loose the whole time.
This week's project ... competition clutch twin disc ;) ... more to follow
... No comments?
Old 05-13-2012, 06:47 PM   #4
Leemoney
Swag Champ
Leemoney's Avatar
...its about time i see somebody do this ..wonder how much power you can make on 18 psi
__________________
DC4 INTEGRA BUILD--->http://www.k20a.org/forum/showthread.php?t=74074
Sold To: TurbanRacer,Remyrounds, b18c, 2217,Lexxi_TegK24, ReppinDa(603),Chompy,ltp0620,purpej1
Leemoney is offline   Reply With Quote
Old 05-13-2012, 06:55 PM   #5
iBoost
K20a.org Advanced User
iBoost's Avatar
wow! great build so far!
what are the power goals?!?
__________________
||| AutoFair Honda ||| K-Tuned |||
D-Rob - Innovative MotorWorks Tuned
iBoost is online now   Reply With Quote
Old 05-13-2012, 07:05 PM   #6
LSThatch
New Member
LSThatch's Avatar
Well it's about time somebody replied! lol ... Thanks guys.
We are going to push the engine and transmission to their limits. I have a good feeling that 3.2L of displacement is going to make a hell of a lot of power ... ok maybe I mean torque ;)
Old 05-15-2012, 08:00 PM   #7
S!K TEG
New Member
i dont know if the imports are the same as domestics but after 3.5L the heads or headgaskets tend to break. either way, i like what i see here.
S!K TEG is offline   Reply With Quote
Old 05-15-2012, 08:19 PM   #8
2tonedc5
New Member
Default
Taking notes for my j powered mini
2tonedc5 is offline   Reply With Quote
Old 05-16-2012, 07:00 PM   #9
LSThatch
New Member
LSThatch's Avatar
We'll see how the heads and gaskets hold up on the 3.5L in the near future.
I have high confidence in them since they are the same MLS design as all 4 cylinder Honda head gaskets and the number of bolts/studs per cylinder is higher (2 2/3 vs. 2 1/2).
Old 05-17-2012, 09:05 AM   #10
Mr. Spade
K20a.org Basic User
Mr. Spade's Avatar
Because race car
Mr. Spade is offline   Reply With Quote
Old 05-17-2012, 07:10 PM   #11
LSThatch
New Member
LSThatch's Avatar
Quote:
Originally Posted by Mr. Spade View Post
Because race car
... huh?
Old 05-17-2012, 07:54 PM   #12
LSThatch
New Member
LSThatch's Avatar
best video of a track pass (just me ... no one in other lane).
Just turn your head or screen sideways ;)
Old 05-19-2012, 02:00 AM   #13
KSeriesCoupe
K20a.org Basic User
KSeriesCoupe's Avatar
KSeriesCoupe is offline   Reply With Quote
Old 05-19-2012, 05:08 PM   #14
jmoney45
New Member
F inn awesome
jmoney45 is offline   Reply With Quote
Old 05-19-2012, 05:34 PM   #15
Leemoney
Swag Champ
Leemoney's Avatar
Sickkkkkkk I NEED MORE VIDS what was your time in that vid?
__________________
Old 05-19-2012, 06:20 PM   #16
quick_ls
Quote:
x2
that sounds badass!!
quick_ls is offline   Reply With Quote
Old 05-19-2012, 08:42 PM   #17
LSThatch
New Member
LSThatch's Avatar
Quote:
Originally Posted by quick_ls View Post
x2
That pass was a 12.11 @ 112mph ... lol
Not the best of the day but a decent 1.68 sec 60'
I love the sound, even with the clutch slipping and it running soo slow.
Old 06-01-2012, 10:30 AM   #18
RatataK26
RatataK26's Avatar
it was spinning to the finish line
__________________
VOUCHES=ronaldve,b18ctrb,bysk24,1320whtrex,b20vtec si,220ek9,unknown_jdlr,carnut4eva,mac2118,Ragingrh ino,98luder,jacamo,2fast4u831,tc011602,himsweet66s ix,hickamhatch,miami_em2,Littlekeel,HondaPACT27,ho twheelz,chaney,Milanored_k20,poisonfreewill,eremoy
RatataK26 is online now   Reply With Quote
Old 06-07-2012, 05:32 AM   #19
LSThatch
New Member
LSThatch's Avatar
went to the track last night ... best pass of 10.61@138mph at 12psi on borg warner S366 turbo .... pump gas:
https://www.youtube.com/watch?v=RZb5...e_gdata_player
more vids to follow
Old 06-07-2012, 05:53 AM   #20
Sonnick
K20a.org Basic User
You picked up a whole lot of MPH from last time.
__________________
2006 ASM AV6-6 Coupe
272/235 SAE - FBO/Untuned
Sonnick is online now   Reply With Quote
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
