im in the same boat as you...its been 7 months and so far this is what i got done:
K24a1 block
Stage 2 sleeves by IB
88mm bore
CP 9:1 pistons
IB spec turbo rods
Crank balanced/micro by Laskey Racing
A2 oil pump+windage tray
all OEM honda bearings
its all together just sittin on the engine stand..i just recently received by Ferrea valvetrain and just waitin to send out my A2 to IB for a stage 2 PnP then my longblock should be pretty much done..
keeps up posted on ur build:up::up:
i got a 03 type s tranny im going to buy lsd for it. and the car just sit there covered and the motor at my friends house we got held up putting the motor together cuz we r swaping a motor on a hatch but im in no rush
did you ever finish the motor and what bearing did you use i just tore down my k24a4 block and im going to start building it and people say bearing are a pain to get the correct
not yet man ill telling you he lags he has many projects at his house like changing out motors porting heads including mine head but i used some acl bearing standard size. are you going to build the k24? what rods pistons r you using?
kool kool well i just took off the front hubs to change the studs to some extended studs
Related Threads
2M posts
94.7K members
Since 2000
