Are all oem injector clips the same? - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Old 04-20-2017, 07:27 AM   #1
dfw
Default Are all oem injector clips the same?
Started noticing misfiring at idle in a buddys car. No cel. Car is stock 08 Si bought a couple months ago.
We found one of the injector pigtail wires has the insulation torn by the clip (wire showing), and maybe even pulled out a little bit of the clip.
The coil packs seem fine, pulled each connector and engine tone changed. Plugs looked fine.
Are all oem k-series injector clips the same? Plan on finding a one with pigtail.
TIA!
dfw is offline   Reply With Quote Quick reply to this message
Old 04-21-2017, 03:52 AM   #2
drtye
drtye's Avatar
Default Re: Are all oem injector clips the same?
yup k series are the same, except for the rdx and newer stuff (08-09ish+). as far as i know all 8th gen civic si are the same.
drtye is offline   Reply With Quote Quick reply to this message
Old 05-09-2017, 09:25 AM   #3
poasdu
same same
ผลบอลสด
poasdu is offline   Reply With Quote Quick reply to this message
