K24z7 in 2002 EP3 - Page 3 - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Old 02-09-2017, 07:38 AM   #41
Default Re: K24z7 in 2002 EP3
Originally Posted by EH6TunerDaniel View Post
In this instance he means he didnt want us to think he did something else instead of working on his project and sharing with us.
Thanks man! Now I got it .
Originally Posted by 309antonios View Post
I apologize for overlooking your question! I did not mean to do so.
No problem .
You remembered me to the right point, I have to ask for my shift mechanism, the fabricator is talking about it, but don't do steps ahead in production of it. I need to ask them again for it.
Old 02-15-2017, 07:52 AM   #42
309antonios
309antonios's Avatar
I made some progress on the shifter and wiring this weekend.
I need the reverse selector arm from the RSX. I had planned to use the EP3, but when I opened it up, it didn't have the necessary cut for the reverse lockout solendoid to actuate properly.
If you have the complete P3t\s shift selector, you will need several parts from the RSX-S shifter to make the swap. Looking at the above image you will need 3,9,13. I would suggest new springs and seals as well. 1,14,15,22, and 21.
309antonios is offline   Reply With Quote Quick reply to this message
Old 02-17-2017, 09:44 AM   #43
309antonios
VSA \ ABS \ EPS wiring are all freaking me out.
VSA\ABS lights concern me mostly because of the ABS sensors. I was planning on putting the VSA unit\ABS Modulator in the car along with the steering angle sensor (steering column) to allow complete operation of the VSA and ABS system. Two things specifically that I'm uncertain about. The YAW sensor? I somehow stumbled upon this unit as being an integral part of the VSA in the SI though I can't find anything about it in the repair manual, electrical manual or any parts documentation. Secondly, I wonder if the toner rings for the ABS and sensors will work with the k24 VSA system. I'm betting voltage and such is the same, but if the count of toner spots on the ring are different per wheel rotation than the civic SI, it could throw the system off.
I was thinking with Flashpro, there is an option to disable VSA, maybe I could just use that to hush the alerts on the dash and simply run the stock ABS pump and components that would be working fine in the background.
I'm also wondering if the VSS\NEP signals are different from the ep3 to 2012 si. I suppose one of those dakota digital thingies would convert the speed signal, possible it could be used for the RPM as well.
I guess I won't know anything until I get in there and start things up. Wiring is coming along. I am still separating the circuits out of the main wiring harness as it's the only way I can wrap my head around it.
Old 02-17-2017, 10:44 AM   #44
309antonios
It's looking like it might be easier to just leave the ABS alone, let is operate as it did stock in the EP3.
It looks like I might be able to simply disable VSA\ABS\EPS lights with flashpro and just know they are working in the background. Same as the SRS. I could run wires to a small harness and plug in the old dash if I needed to troubleshoot.
Inspection......I'm....not going to look legal.....
Old 02-17-2017, 10:45 AM   #45
309antonios
To my own quote, I wouldn't make this car a daily driver without knowing the safety systems are working as they should. Primarily SRS and ABS.
Old 02-18-2017, 06:04 PM   #46
309antonios
10 hours of wiring today....It's getting there!
Old 02-19-2017, 06:51 AM   #47
Congrats man! You will keep all the electronic supporter stuff?
Old 02-19-2017, 08:00 AM   #48
309antonios
I think I am ditching VSA and the TPMS stuff. I might have to deal with some warnings on the imid on every start up. We will see!
Old 02-24-2017, 09:59 AM   #49
309antonios
I received the secondary shift arm last night. Everything went together just right. All four holes in the RSXS mount line right up with holes already in the tranny. The rear two holes need to be tapped however.
I will get another tap tonight for the smaller bolts and get it all mounted.
Old 03-01-2017, 04:22 AM   #50
309antonios
Still wiring! I removed the front fenders and am doing a wire-tuck with complete custom harnesses.
Old 03-03-2017, 11:48 AM   #51
309antonios
Car is doing some weird shit! I didn't realize the multiplex control unit was really more then a secondary fuse box. EEEEK!
Old 03-13-2017, 05:38 AM   #52
309antonios
It's been soooo cold in the garage! Absolutely no progress the past few weeks!
Old 03-13-2017, 06:48 AM   #53
15 C here, thanks to Gulf Stream.
Old 03-16-2017, 07:06 AM   #54
309antonios
Another 2 feet of snow on the ground......I'm losing interest in everything in my garage!..........
Old 04-03-2017, 12:28 PM   #55
309antonios
Not dead yet!
Just ordered complete new OEM bushing set with EVERYTHING, Bilstein shocks, Tein h-tech springs, ingalls front\rear camber adjustment, LBJS, tierod ends, front\rear links and SS brake lines. New rotors and pads ill pick up locally. No racing so I tossed the big brake kit out the door.
Electrical is coming, car starts and runs, so I am not worried about that, just all these lights on the dash, except the CEL!
Old 04-03-2017, 12:45 PM   #56
Not dead yet!
If I would update my 86x86 built thread like you do I would have done the 3rd engine LOL . Good progress man!
...except the CEL!
Which ones?
You have still snow? Since 2 weeks spring is showing his muscles...15-20 C...really sunny all the day time .
Old 04-06-2017, 11:31 AM   #57
309antonios
Literally all of them! SRS, VSA, ABS, TPMS, EPS...... Heh heh.... plus the dinger in the dash NEVER shuts off - something missing in the SRS system I think...I'll figure it out!
I have SO many parts in the garage right now. All new bushings, EVERYTHING! Springs and shocks are here and new rotors and pads. Just went with OEM brake parts plus SS lines. Nothing fancy. The suspension should be smooth though.
This weekend is supposed to be warm, but it's also the first weekend my girlfriend and I will have together. Sorry EP3!
Old 04-07-2017, 07:52 AM   #58
309antonios
I figure absolutely everything is being replaced, so while I have it apart.... I bought 2 new NTN bearings for the front and 2 NTN hub assemblies for the rear. I guess I should do front wheel studs too!
Old 04-19-2017, 05:43 AM   #59
309antonios
After 15 hours and lots of patience, the car is on the ground again. I am getting a CEL now but I think it's because I snagged the secondary coolant sensor in the radiator (not a fan switch!).
The car has new (all oem honda parts) bushings, endlinks, bearings, wheel studs and bolts. All wrenched together with antisieze. New Rotors and pads were installed and cleaned up the calipers and slides with new grease.
I had to have someone assemble my bilsteins and tein springs for me as I couldn't work with the cheesmo spring compressor I had. But now that has been installed with all new tie rod ends and ball joints. It moves around the garage nice.
I am finally getting some more comfortable temps in the garage so cleaning up the wiring is all that is left. That is a big job though, right now it's a hoot......
Thread ain't dead yet. I am going to have the exhaust made custom by a local shop. I though I would give it a shot, but.....my welding is trash....
Car is still in progress. I keep dreaming about it!
Old 04-20-2017, 07:11 AM   #60
Do you have a picture of the car from it's status? I would appreciate to see it .
