Ridgeline swap j37a4 short block help?? - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Old 02-09-2015, 07:59 AM   #1
anthonyfa18
anthonyfa18's Avatar
Default Ridgeline swap j37a4 short block help??
Hey guys I need some help I was luck to get a short block from a tl shawd 2009, the short block is in need of a rebuild and also need 2 heads and a intake manifold. My question is what is needed to install this motor into my Ridgeline?? Also are all J series V6 heads interchangeable???
Acura Metropolitain
My Race Car: Da9 k20a2 build
My Daily Drive: 2007 Honda Ridgeline Ex-LSR
anthonyfa18 is offline   Reply With Quote Quick reply to this message
Old 02-19-2015, 09:17 PM   #2
jealous1shateric
Default Re: Ridgeline swap j37a4 short block help??
Not all head are interchangeable. They all change depending on uear
jealous1shateric is offline   Reply With Quote Quick reply to this message
Old 02-20-2015, 08:55 AM   #3
Sonnick
You can swap any heads with work I believe, but a direct swap will require 2nd generation heads. Either J35z heads or J37s. I have a set of 2010 MDX heads (2nd generation J37a1) for sale. PM me if you're interested.
J30a5 Accord 6spd -- 13.28 @107.56
Full Bolt ons/Street Tune/3.94 Final Drive
Sonnick is offline   Reply With Quote Quick reply to this message
Old 02-03-2017, 05:48 PM   #4
anthonyfa18
let say i got my self a complete j37a4 from a tl 2009 what do i need to make it work in my 07 ridgeline ???
Acura Metropolitain
Old 02-03-2017, 07:38 PM   #5
Bouckaroo
Look into whethere the botl pattern for the ridgeline is the same as the TL SH AWD.
I know that some of the j37 blocks have unique bolt pattern that only fits those years j37.
Bouckaroo is offline   Reply With Quote Quick reply to this message
Old 02-04-2017, 08:00 PM   #6
anthonyfa18
I am 99% my 07 ridgeline Tranny will fit on a j37a4
Acura Metropolitain
Old 02-05-2017, 07:42 AM   #7
Bouckaroo
I was just double checking as some of the J blocks post 08 do not have matching bell housings.
I have a j37 mdx block form 07 and it will not mate to my J35a8 transmission from the 08 tl-s 3.5l.
So, I was just trying to be helpful to make sure you don't get caught with your pants down.
Is the TL SH AWD setup you have, is that a manual setup? I am curious as I looked and looked and could never find the 6mt TL SH AWD Transmission and setup anywhere.
Old 02-06-2017, 06:48 AM   #8
anthonyfa18
the only swap i found so far and is working is
but he is 2009 and up ridgeline and he swap in a j37a4
http://www.ridgelineownersclub.com/f...ged-build.html
and found this on j32a forum
I know a few people have had issue with transmission fitment due to some engine block that are a bit different. I have put together a list to show these differences. This list could also be used to find a proper transmission for a give engine. J30, J32, J35 and J37 do not play a role in what is a skinny block and a wide block. Its more Year and model. most Hondas/Acuras saw the change over in 2007/2008 but the RL and Ridgeline saw them earlier. I hope this helps some people.
Odyssey
1999 to 2006 skinny block
2007+ wide block
99-04 11000-P8F-810 3.5L-skinny 4auto + 5auto
05-06 11000-RGL-810 3.5L-skinny 5auto
07-10 11000-PVK-A00 3.5L-wide 5auto
11-14 11000-R70-A01 3.5L-Wide 5auto + 6auto
Accord V6
Pre 1998 used C series V6
1998 to 2007 skinny block
2008+ wide block
98-02 11000-P8A-810 3.0L-skinny
03-07 11000-RCA-810 3.0L-skinny 6speed + 5auto
08-12 11000-R70-A01 3.5L-wide 6speed + 5auto-wide
13-14 11000-5G0-A11 3.5L-wide 6speed + 6auto-wide
TL
Pre 1999 used C series V6
2007+ wide block
99-02 11000-P8F-810 3.2L-skinny 4auto + 5auto
02-03 11000-PGE-810 3.2L-skinny 5auto type S
04-06 11000-RDA-810 3.2L-skinny 5auto + 6speed type S
07-08 11000-PVK-A00 3.2L-wide 5auto
07-08 11000-RJA-000 3.5L-wide 5auto type S + 6speed type S
09-14 11000-RK2-A02 3.7L-wide 5auto AWD + 6speed AWD(10+)
09-14 11000-R70-A01 3.5L-wide 5auto FWD + 6auto FWD(12+)
Ridgeline
2006+ wide block
06-08 11000-RJE-A01 3.5L-wide 5auto AWD
09-14 11000-R70-A01 3.5L-wide 5auto AWD
Pilot
2003 to 2007 skinny block
2008+ wide block
03-04 11000-P8F-810 3.5L-skinny 5auto AWD
05-08 11000-RYP-A00-wide 5auto FWD
05 11000-RGL-810 or 11000-PVJ-810 3.5L-skinny 5auto AWD
06-07 11000-PVK-A00 or 11000-RJE-A01 3.5L-wide 5auto AWD
08 11000-PVK-A00-wide 5auto AWD
09-14 11000-R70-A01-wide 5auto Fwd + AWD
RL
pre 2005 used C series V6
2005+ wide block
05-08 11000-RJA-000 3.5L-wide 5auto
09-12 11000-RYE-A00 3.7L-wide 5auto + 6auto(11+)
MDX
2001-2006 skinny block
2007+ wide block
01-02 11000-PGE-810 3.5L-skinny 5auto AWD
03-06 11000-RDJ-A00 3.5L-wide 5auto AWD
07-09 11000-RYE-A00 3.7L-wide 5auto AWD
10-13 11000-RK2-A02 3.7L-wide 6auto AWD
14 11000-5G0-A11 3.5L-wide 6auto AWD
ZDX/Crosstour
2010+ wide block
10-12 11000-R70-A01 3.5L-wide 5auto FWD + AWD (Crosstour only)
13-14 11000-5G0-A11 3.5L-wide 6auto FWD + AWD (Crosstour only)
10-13 11000-RK2-A02 3.7L-wide 6auto (ZDX only)
RLX
2014+ wide block
CL
1997-1999 2001-2003 skinny block
97-99 11000-P8A-A02 3.0L-skinny 4auto
01-03 11000-P8F-810 3.2L-skinny 5auto
03 11000-PGE-810 3.2L-skinny 6speed type S
By engine blocks
P8A-A02 skinny 97-99 CL 3.0L
P8A-810 98-02 Accord 3.0L
P8F-810 99-04 Odyssey 3.5L, 99-02 TL 3.2L, 03-04 Pilot 3.5L
PGE-810 02-03 TL 3.2L type S, 01-02 MDX 3.5L, 03 CL 3.2 Type S
PVJ-810 05 Pilot 3.5L
RGL-810 05-06 Odyssey 3.5L, 05 Pilot 3.5L
RDJ-A00 03-06 MDX 3.5L
RCA-810 03-07 Accord 3.0L
RDA-810 04-06 TL 3.2L type S
RJA-000 07-08 TL 3.5L type S, 05-08 RL 3.5L
RYE-A00 09-12 RL 3.7L, 07-09 MDX 3.7L
RK2-A02 10-13 TL 3.7L AWD, 10-13 ZDX 3.5L AWD
RJE-A01 06-08 Ridgeline 3.5L AWD, 06-07 Pilot AWD
PVK-A00 07-10 Odyssey 3.5L, 07-08 TL 3.2L, 06-08 Pilot 3.5L AWD
R70-A01 11-14 Odyssey 3.5L, 08-12 Accord 3.5L, 09-14 TL 3.5L FWD, 09-14 Ridgeline 3.5L, 09-14 Pilot 3.5, 10-12 Crosstour 3.5L
5G0-A11 13-14 Accord 3.5L, 14 MDX 3.5L, 14 RLX 3.5L
FYI the 2010 TL came with an AWD 6 speed that could be fun for a swap!
Acura Metropolitain
Old 02-06-2017, 08:28 AM   #9
Bouckaroo
hmmm interesting list. I wonder why my 07 j37 doesn't fit the 08 3.5 transmission?
In anycase, I hope you swap works out and runs great!
Old 02-06-2017, 02:49 PM   #10
anthonyfa18
Did you try it ??? Do u have any pics ???
Acura Metropolitain
Old 02-07-2017, 08:21 AM   #11
Bouckaroo
LMAO, of course I tried, hence why I said the trans wouldn't bolt to the block.
Currently I am out of town for work, but when I get back home ill gladly post pictures of both the block and trans.
Again, I will say, the j35a8 trans I have will not fit and bolt up to the j37 block that I have. If it would fit, I would already have the j37 in the 08 tl to replace the 3.5l j35a8 that is in it currently.
Old 02-07-2017, 11:56 AM   #12
anthonyfa18
what j37 block was it j37a1??? j37a2?? j37a4??? j37a5???
Acura Metropolitain
Old 02-07-2017, 02:44 PM   #13
Bouckaroo
Not sure if it is a j37a1 or a j37 a2, but, it will be one of those two, as is t comes from a 2007 acura mdx.
When I get home iw ill double check the exact serial number.
Old 02-08-2017, 05:19 PM   #14
anthonyfa18
Well look at this tsx j37 swap it running the 08 type s 6 speed tranny https://m.youtube.com/watch?v=4Q9AXlZYCvc
Acura Metropolitain
Old 03-22-2017, 09:04 AM   #15
anthonyfa18
this will help you too
http://www.v6performance.net/forums/...h-gen-av6.html
Acura Metropolitain
