K24z7 in 2002 EP3 - Page 4 - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Old 04-21-2017, 09:51 AM   #61
AWOC
AWOC's Avatar
Default Re: K24z7 in 2002 EP3
Originally Posted by 309antonios View Post
After 15 hours and lots of patience, the car is on the ground again. I am getting a CEL now but I think it's because I snagged the secondary coolant sensor in the radiator (not a fan switch!).
I was able to shut the secondary sensor off via Flashpro in my TSX.
Stance = Ricey
AWOC is offline   Reply With Quote Quick reply to this message
Old 04-23-2017, 02:24 PM   #62
309antonios
309antonios's Avatar
Thanks AWOC, maybe I'll just leave the k20a thermo switch in there and wire it up. Probably unneeded, but can't hurt.
I lied to you all, I didn't do all the bushings. Today I completed the rear knuckles with all 3 new bushings on each side and did the front trailing arm bushings. Those RTA bushings are a real turd to get out....Ugh!
309antonios is offline   Reply With Quote Quick reply to this message
Old 04-24-2017, 12:11 PM   #63
309antonios
Still scratching my brain a bit on the lower radiator hose. Would love to find a preformed hose that someone made for the K24 swap.
I'm stuck on such a simple problem.... Many have suggested swapping the thermostat housing. I grabbed the housing from the old motor and unfortunately the bolt pattern is a bit different. I can't use the Ktuned swivel housing either because of this.
Old 04-24-2017, 05:17 PM   #64
AWOC
AWOC's Avatar
Something a local machine can do for you? If you send me the parts I can CAD them up and send it to my machine shops. It's not going to be a $20 fix, but it's option.
Stance = Ricey
