I got a k20a3 engine swap (not s type). The ngine has 74,000 miles. It comes with engine, tranny, engine harness, ecu, header, cataylic converter, shift cable, immobolizer system and keys. I pull the motor from a wreck rsx so i have title on hand. Asking $1500.00 shipped. I'm located in Minnesota.
I got a k20a3 engine swap. It comes with engine, tranny, engine harness, ecu, header, cataylic converter, shift cable, immobolizer system and keys. I pull the motor from a wreck rsx so i have title on hand. Asking $1500.00. I'm located in Minnesota.
If you have this in a month or two I will be getting back to you unless i change my mind on what im gonna do with my del sol. Waiting on my school refund check.
I will do a compression check on the engine. I pulled it off a wreck rsx. But i only have one axle for it. I cut the other one off just so i can pull the engine out because i don't have the wheel lock.
Hey, you said you had a k20a3 complete engine right? I just got an rsx shell and i am need of any k series engine? Can you send me a private message. Thanks
i am assuming this swap is complete which includes motor, tranny, ecu, shifter cable/box/etc, axles, harness, sensors.....if this is the case then i have 1500 for you....also i need the suspension....are you selling that...pm price
actually if you still have this this....then pm me contact number... i may be able to come and pick this up myself later next week....so you won't even need to ship..lmk
I need these, let me know if you have 'em all. (Swapping into a 02 civic coupe)
Parts needed:
-intermediate shaft
-O2sensor for the same type of motor
-subframe from a rsx or
-shifter cables
-headers and downpipe
-throttle cable
-clutch lines from master to slave cylinder
-high pressure power steering hose
-power steering return line
-ac line from compressor to condenser
-axles
-radiator and fans
-upper and lower radiator hoses
I sent you an email about the complete swap - I'm a high school student working on a home-built Ariel Atom style race car, in need of a motor/transmission/immobilizer/key setup. I'm willing to pay more than $1500 for a couple extra bits from the RSX.
i have a brother in Minneapolis MN, he goes by rat if you know him, if this swap is still available by the time i have the money, i'll take it, my bro will pick it up, or you'll ship it to me, of course i'll pay shipping...:driving:
You have insufficient privileges to reply here.
