K20A2 setups. - Page 11 - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Old 01-18-2017, 01:30 AM   #201
Default Re: K20A2 setups.
Originally Posted by molodoi View Post
Same setup with 54mm TWM ITBs
Very nice and impressive result . A picture of them would be most interesting .
BTW, welcome to the best K20a.org ever , molodoi!
Old 01-18-2017, 01:53 AM   #202
molodoi
Thx Markus, but I am here since 2005 ;)
Here is a picture for you.
molodoi is offline   Reply With Quote Quick reply to this message
Old 01-18-2017, 03:06 AM   #203
I did see it, but never saw you writing here before...I welcome those guys writing here, as K20a.org need them. So I did it intentionally .
Thanks for your picture, man! WOW, that's a surprise to me now seeing the ITB's. The torque is pretty high for them combined with the DC 2.2. What was the porting task (valve seat, valve size, partly port wall or...)? What are the measurements of a stock K20A2 engine on that dyno? Just for my comparison
Old 01-18-2017, 11:00 PM   #204
molodoi
It is Pro TSX head from 4piston, with 36/30 valves.
Dyno I was using usually show around 196 hp on European EP3 k20a and about 200 hp on FN2.
Old 01-18-2017, 11:35 PM   #205
Thanks for the information about the head and the dyno reference measurements to get the numbers sorted.
Pretty nice result, molodoi!
Old 01-19-2017, 11:13 AM   #206
zof484
Here are some k20a love we made in Russia.
86x86.5
ASP 4-1
Ips intake 80mm
ported head
DC 2.2
12.4 CR
98 octane
Very nice, youngster
zof484 is offline   Reply With Quote Quick reply to this message
Old 02-15-2017, 10:53 PM   #207
zof484
Zof spec K20
289hp @ 8400
261nm @ 7200
or
265hp @ 8200
274nm @ 6000
Tested some different induction/header combinations for
different type of racing.
Old 02-15-2017, 11:08 PM   #208
zof484
245hp @ 7200
278nm @ 5000
-k24a3
-ported rrc + j35 tb
-4-1
-3" ex
-45vtc
-ktuner ecu
Rbb vs rrc.
Stock cl9(stock ecu) vs 245hp
Gained +60hp @ 6000
Old 02-15-2017, 11:23 PM   #209
DonMizzi
Thanks Zof for sharing
More informations about K20 configuration and dyno
thanks
DonMizzi is offline   Reply With Quote Quick reply to this message
Old 02-19-2017, 08:10 PM   #210
malkolm666
malkolm666's Avatar
Originally Posted by zof484 View Post
231hp @ 6600
279nm @ 5500
-k24a3
-ported rbb + j35 tb
-45 vtc
-4-1
-3" ex
-ktuner ecu
245hp @ 7200
278nm @ 5000
-k24a3
-4-1
-3" ex
-45vtc
-ktuner ecu
Is that the same engine? What differrence was made? K20a2-oilpump?
"Once a K, ALWAYS a K!"
Vouches: tedk20, 2000EK4, Asse, Junior 7, jdm94civic, bysk24, k20sean, Al.BrEeZy, naudlee, jesnuts83, SchueString Racing, cstyleaccord, abel, Trevdog, baddrummerboyy, Jas9848, Alex_CTR, Jaydee, ProcessRacing, K20R EG6,
malkolm666 is online now   Reply With Quote Quick reply to this message
Old 02-19-2017, 10:11 PM   #211
zof484
Different intake manifold.
Stock k24 oilpump.
K20 is alot of custom stuff.
Old 05-18-2017, 10:22 PM   #212
zof484
299,5hp @ 8400
273nm @ 5600
-K20
-itb
-custom 4-1
-motec
-98 fuel
-64mm intake restrictor
Old 05-19-2017, 12:50 AM   #213
GoThanh
That's crazy power and torque for a k20!
GoThanh is offline   Reply With Quote Quick reply to this message
Old 05-19-2017, 02:46 AM   #214
299,5hp @ 8400...273nm @ 5600...K20...
Great result zof484!
You did partely prove what I wanted to verificate with my project. I know there are some more modifications needed for it, but it shows the K20 Allmotor is able to reach more than 16 bar of BMEP (around 130 Nm/L of an 86x86 engine) and not only peak-wise.
An amaizing result man!
What do you mean by 98 fuel? Do you mean rated according ROZ, MOZ or AON = (ROZ + MOZ) / 2?
Old 05-19-2017, 04:28 AM   #215
zof484
Thanks.
Its 86,5x86 k20.
Its regular gas. Not e85.
Old 05-19-2017, 05:29 AM   #216
...Its regular gas. Not e85.
So you mean 98 ROZ, which is called Super or Super Plus here in the South?
Zof484, could you state the torque values for following engine speeds?
  • 4500
  • 6500
  • 7500
I would appreciate it. I am just curious how much of mine engine project aim you have already reached.
Old 05-19-2017, 07:10 AM   #217
I couldn't resist to analyze the torque line a bit:
  • BMEP of 16+ bar from 5250-8000 rpm, about 2750 rpm broad
  • Seems to be the engine runs the Schrick cams of K20 engine no. 14
  • Seems to be the further torque win is done within further head modification and the ITB's, which are seemingly well designed
I am not sure if the win on top is done, in addition of the ITB's, with an e-coolant pump or further improvement of the head, as the win around 10 Nm from 4500 rpm and above.
Exciting stuff...need to dive in it at the weekend . Are we at K20 No. 18 or 19? Anyway it is the best of that row
Old 05-24-2017, 10:01 PM   #218
zof484
Cams are different and alot of work is done to the head.
E pump is also added to setup.
4500 230nm
6500 265nm
7500 265nm
Old 05-24-2017, 11:30 PM   #219
Thanks zof484, I already analyzed it. That torque line reaching a level my 1D engine simulation (and hopfully my engine built too) reaches with a certain setup too, just a bit broader from 4.5-8.5 krpm. We talked about it back in Oct. '15, now your engine showed it is possible to reach more than 130 Nm/l over a wider revving band. That's great, man!
It is seemingly a level, where it is not smart to talk about it in details. That's a pitty...
Old 05-25-2017, 02:39 AM   #220
malkolm666
malkolm666's Avatar
Whats the gains with a E pump? 5hp?
